I GOT A FEW BITS AND PIECES THAT ARE NO LONGER REQD ALL OFFERS CONSIDERED!!!
LOCATED SOUTHSIDE BRISBANE
RB20DET PARTS:
CAS (CRANK ANGLE SENSOR) semi polished looks good az
TOP HALF OF PLENUM x2
BOTTOM HALF OF PLENUM WITH INTAKE RUNNERS X2 SETS
1 SET OF STANDARD CON RODS
1 RB20DET CRANK IN GOOD CONDITION
5 STANDARD PISTONS IN GOOD NICK 1 COMPRESSED A SELF TAPPED SCREW SO NO GOOD
RB20DET STANDARD OIL PUMP
RB20DET JPIPE SEMI POLISHED WITH STAINLESS BLANK OFF PLUG LOOKS SWEET
INLET AND EXHAUST CAMSHAFTS X 2 SETS GOOD CONDITION ALSO HAVE CAM CAPS AND BOLTS IF NEEDED
RB20DET STANDARD TURBO NO SHAFT PLAY COMES WITH OIL FEED/BANJO BOLTS AND OIL DRAIN AND 8PSI RB25 ACTUATOR HAS THE COMPRESSOR COVER SEMI POLISHED LOOKS VERY TIDY THE EXHAUST HOUSING WAS SUBJECTED TO 3 COATS OF STEALTH BLACK HIGH TEMP PAINT RATED TO 650 DEGREES HAS BEEN RESEALED WITH HIGH QUALITY BLUE RTV SILICONE IS READY TO BOLT AND GO EXCELLENT CONDITION AND APPERANCE.
COMPLETE RB20DET STANDARD HEAD IN GOOD CONDITION STILL VERY SMOOTH AND HAS FACTORY MACHINE MARKS LOW K PERFECT FOR REPLACEMENT
COMPLETE RB20DET BOTTOM END IN GOOD NICK BOLT HEAD ON AND GO SPRAYED STEALTH BLACK HIGH TEMP PAINT CLEANED LOW K AND READY TO ROCK
RB26DETT CRANKSHAFT SUITABLE FOR RB24 BUILD OR 26 REPLACEMENT NO PROBLEMS WITH IT SMOOTH SURFACES ON JOURNALS ETC NEVER RUN A BEARING AT WORST COULD DO WITH A QUICK MICROPOLISH SUITED TO STANDARD SIZE BEARINGS.
RB20DET CAM COVERS 2X TOP COVER 1X BOTTOM COVER
RB20DET VALVE COVERS GOOD CONDITION 2 SETS AVALIABLE
ALL IN GOOD WORKING CONDITION POSTAGE CAN BE ORGANISED JUST ENQUIRE OFFERS AND SWAPS FOR THINGS OF INTEREST ALWAYS CONSIDERED
https://www.sau.com.au/forums/topic/312174-rb20det-parts/
price on cam covers
valve covers
and RB26 crank
please
ok prices for you
valve covers 30
cam covers 40
rb26 crank 250 ono
will do package price on all that if you want too
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5143119
  • 3 weeks later...
just got in complete rb20det turbo engine has 126ks had 100k service done at 95k by nissan japan very good condition sell/swap doesnt have coilpacks ignitor or loom good replacement can come fitted with rb26 injectors also
call text pm or post 0450 728 189
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5175937
  • 5 months later...
Hi there!
Do you have a crankshaft in good condition?
In case you have, would you be interested in shiping one to sweden?
Its impossible to get over here!
Best regards! Markus
https://www.sau.com.au/forums/topic/312174-rb20det-parts/#findComment-5468782
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
