alright, another thread, starting to get old i know. but an issue has appeared.
the issue started a few days ago, but ill start from the very start. the first time i drove the car i noticed that sometimes the fuel pump would get really loud, but be quiet other times, completely random too. the noise doesnt sound like ur normal average healthy fuel pump buzz either.
anyway, last few days ive had big issues with running out of fuel really quickly, even before the fuel light comes on. the first time it ran out i put in like 20 litres and within about 40k's of driving it was empty again. when it runs out it runs out differently to what im used to as well, a consistent miss appears, until eventually breaking down and not starting, or idling rough. same story the 2nd time it ran out, 10 litres in, got me barely more than 10k's before it wouldnt start. i thought this was just a fuel leak, as there is both a burnt and unburnt fuel smell in the air, certainly last night when trying to start it there was a strong wiff of unburnt.
now today i go to put some fuel in it, and the thing is just breaking down under load consistently, even with probably 20ltrs or more in. around 7% inj. duty it starts breaking down. one thing i noticed though, is i think my PowerFC reset overnight, i had a fair few people in the car and something may have happened, not sure. but all my monitor settings were reset etc.
i cant think of anything else worth mentioning, maybe that the knock is still sitting at max of 13ish? also as far as the fuel system goes, apparently it has a adj fuel press regulator, and sard inj (unsure of size). fuel pump is unknown, but im thinking of pulling it out regardless and checking if it's stock, if it is i can pretty much be guaranteed it's the issue, but id still like to get opinions first as it isnt exactly easy to work on my car here.
cheers
https://www.sau.com.au/forums/topic/312176-fueltuning-issue/
pulled out the pump today, not sure what it is, has a nissan symbol on it which makes me think its stock (RB20 or RB26), but its been so long since i pulled mine out at home to replace with an 040 i cant remember what im looking at.
numbers and details on the pump are as following:
A42-621 B70
JECS
3217
pics:
if that was the case the car wouldnt the car struggle to start every time it's been sitting because the lines would be dry? it starts fine, it's generally after a bit of a drive it runs out of fuel.
im starting to think it's a separate issue, maybe the powerFC is in a limp mode or something, i dont know, what could cause u to lose ur tune, or for the powerFC to go into a failsafe mode or something?
another suggestion has been made that maybe it's the vacuum lines to the fuel regulator or something? causing issues with picking up the fuel?
not sure, cant go check atm as it's snowing hard here. thats also another point i probably should have mentioned, the car has been driving around in cold weather for the last few weeks, as low as a few degrees below freezing.
been searching the part numbers, and looks like it might be a R32 GTR pump, going to confirm soon, so focus is back on the powerFC for now.
one thing i forgot to mention is before it started to hesitate, since ive had the car its hunted on idle, up and down as soon as the car heated up (and came off cold start), now since this hesitation has started, the car idles perfectly, or at least did for the drive i took it for the other day. this is what makes me think its a tune issue.
you have a fuel leak IMHO
yeh it sounds like that's the case, but would that attribute to the consistent hesitation at the same engine load each time? if im honest it feels electrical, not like fuel starvation. im thinking there are seperate issues here, one being a fuel related issue that's pissing away fuel, and one with the tune that's causing the hesitation.
as i said, it just seems all too weird that in one day, it's gone from no hesitation, hunting idle, to next day, full hesitation at the same load every time, perfect idle, and the monitor settings on my PFC have reset (possibly the whole PFC, i dont know how to check)
Have you checked the sparkplugs, every single one since one might be fine and the other bad, are they white/black, gooey? A good way to determine if its a fuel issue at all, would be white if its running lean.
Also i could imagine the stock lambda might be damaged, making it hesitate as it wont give the correct values to the ecu, making it run bad and sip more fuel?
would that happen overnight though? it was running fine one day, smooth all the way to redline, albeit a hunting idle. then next day i go to turn the car on it's non-stop hesitating. it's like the issue manifested between the car dying the night before (ran out of petrol), me putting 10ltrs of fuel in from a jerry can, and then turning on the ignition. i thought about it possibly being a bad batch of fuel (or even possibly wrong fuel as the jerry can was filled up by some japanese dude, and i dont have a good enough grasp on japanese to notice what fuel he's putting in lol) , but id expect some knock or something?
once again it just seems too suss that its just a coincidence that the PFC monitor settings defaulted the same time. i had drunken mates in the car at the time, in fact 2 sitting on top of each other in the passenger seat, thinking maybe something was kicked and maybe a wire knocked loose or something.
yep wire loose would reset the pfc.
installed my pfc this week to my rb26dett r32 sedan, but couldnt save (would reset) because a wire to the ecu pinout was faulty.
replaced a small section of 1 wire and all was fine.... had to flick wires a few times to find out which one was cutting on/off.
might want to start at the ecu wiring, flick each wire while engine running and see if you have a 'corroded' wire
weird, but age of these cars would suggest that its possible
as for sucking down fuel, yeh it could be the pfc / oxygen sensor / afm / plugs etc, try my above suggestion 1st,
also perhaps try to look for a pinhole fuel line leak?
fine at idle, but would spit out fuel once under enough pressure
good luck mate
good luck mate
champ mate, will check tonight.
do you have the boost control kit?
when the PFC is data init'd to defaults the boost kit is turned on by default
this means, if yours was "reset" and you aren't using the boost kit the engine check light would remain on until you disable the boost control kit
the PFC has no limp mode or back out mode other than what the stock ECU has
and this is your typical if AFM is dead, cap rev limit at 2500rpm etc - really basic rev cuts and idle protection
it wont know if your fuel pump is being gay or leaking fuel etc
ok, so some news.
fuel pump went back in tonight, fuel tank was still pretty much where it was a few days ago, so ruling out a fuel tank leak (probably)
took it for a drive, same hesitation. had a search through the commander, found a AF setting, was set on R33 GTR (what looks to be the default). changed it to Z32 AFM (im running twin Z32's atm) and the hesitation stopped.
the car seemed to be running ok, except when i got to some hills and put my foot down a bit. car runs like dogs balls. so thinking it's definitely been reset, and running a shitty default map.
now, a few things, these are the max's i got, from putting my foot down once:
A/F: 5115
Ign-t: 20 idle
40 max
INJ-D: 96.5%
knock: 14
RPM: 4524
boost: +0.66kg/cm2
now as u can see, something's wrong, i was barely getting 75% inj duty before when running bout .9 bar, on redline, now im pretty much maxing injectors out with bugger all rpm, or boost.
i ran a sensor check, and this is what i came up with.
AF-1: 1.07
AF-2: 1.07
THRO: 0.46
BOST: 1.34
WTRT: 1.34
AIRT: 3.28
02-1: 1.44 (changes with revs)
02-2: 0.02 (doesnt change at all with revs)
Key: X=empty circle O=solid circle
IGN: O
STR: X
IDL: O
A/C: X
PWS: X
NTR: X
***: X
***: X
ECC: O
WRN: X
F/P: O
FP1: X
FP2: X
02H: O
ACR: O
FAN: O
the thing that caught my eye was the low voltage of the 2nd 02 sensor, i was thinking before, either it could be buggered, or im wondering if with the big single setup, they ditch one of the 02 sensors, then tell the powerFC this, and obviously the FC going back to default, it would be expecting 2.
i dunno, just a thought.
version of PFC is:
RB26DETT
Power FC
Ver8.04A
FC COMMANDER3
Ver5.01A
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
