Hey guys up for sale is my 1999 R34 Skyline GTV
Manual
80,000kms (genuine as i imported it myself)
Immaculate Condition
Power Steer
Air con
Carbon garnish pillars
Weather shield lips above windows
Factory Floor Mats etc
Cause its the GTV you get all the turbo options minus the turbo... So
LSD
Big Brakes 4 pot fronts and 2 pot rears
Front and Rear Strut Braces
Turbo spec suspension(upgraded again on this car)
Mods:
High Compression 11.8-1 (shaved head)
Adj cam gears
Full Exhaust With Varex Muffler(varible niose levels from remote control)
Haltech Platnium Interceptor with high and low octane maps.
124RWKW
Gates Racing Timing belt and rad hoses
Oil Cooler
Gab Coilovers
Whiteline 27mm and 19mm Swaybars
Origin Boot lip spoiler
Car Comes with 17x9 inch Panasport Rims with brand new Yokohama A-driveR1 tyres
Not with gtr wheels...
I have some spares that ive picked up over the years, which will come with the car if wanted.
Asking Price $15700 ono
Call or sms Matt - 0415334551
Located in Sydney(the Shire)
    • Dang I looked at this for so long until I realised it was for the inner rod. I was so confused. This looks like a great tool. Another injected plastic box for my collection. I for one am a torquer. I'm far too anxious and neurotic to not use the correct torques whenever I can. I do honestly feel like my wheels will fall off if I dont.
    • Not sure if you're being serious? I, and all the car people i know, ALWAYS use a torque wrench for wheel nuts. I assumed any car person, apart from tyre centre monkeys with rattle gun in hand, would do it properly.  Anyway, no further reply from me on this unless legit discussion from OP or his query so, over to you, knock yerself out.
    • I was wondering about this. I'll do some research.
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
