Enkei 6 spoke 17"x8" 5x114.3 stud pattern +38mm offset with near new rubber
I'm selling the Enkei wheels which were originally on my Stagea when it was imported, with near new tyres.
Tyres have done less than 3000kms (propbably still have 95% left in them)
The tyres are Sumitomo HTRZ 3 235/45ZA17(~$220 each new) and are in my opinion excellent equipment. Read a review if you are unfamiliar with them.
To satisfy curiosity, I am selling because the wheel offset is incorrect for a stagea 260rs (needs a +20 offset rear) and caused the demise of my original suspension due to clearance issues.
The wheels are in excellent condition, no damage to inside rims and have very little scratching - one wheel has about a 5 cm segment of very minor rash.
In chasing down some vibration in my car I have had all the wheels checked and corrected where necessary by Rallymax in Mitchell (can provide receipt)
The wheels have no centre caps (can be purchased for about $20 on net), I will provide the correct wheel nuts for fitment with the wheels. tyres currently unfitted, let me know if you want then fitted or not.
Wheels, tyres, nuts & washers - $2200 ono, inspections welcome.gallery_65396_3728_4147403.jpg
https://www.sau.com.au/forums/topic/312203-wheels-for-sale-enkei-6-spoke-17x8/
Yep, just found a pic of them on an evo.
Thanks for that, I will post them on one of the evo forums as well.
Please make an offer, I will make sure to update this thread if they sell.
price drop... Now $2000 ono
will swap for +30 offset wheels of similar fitment
will swap wheels without tyres for good 17x8 +30 wheels of similar fitment
open to suggestions,
these things are in excelent condition.
  • 3 weeks later...
The guys on the evo forum are having a field day with this one (priced just a little too high)...
I had little idea of what they would sell for at the time (Bruce at rallymax indicated they're worth bout $1400).
As it happens, I have found a use for the tyres so theyre no longer in the deal.
$1100 (or first reasonable offer) for guaranteed straight wheels + the nuts and stuff, no tyres.
Edited by sooticus
  • 4 weeks later...
    • That's a short. Find the short. It will be somewhere between that fuse and the headlight. Start by removing the plugs from the back of the headlight and dimmer switches, and measure resistance to earth. Supply side (power from the fuse) should have none. The other side should have resistance compatible with whatever globe(s) is there (which is relatively easy to say for a normal globe, perhaps not as easy to say for LEDs). Anyway, if you have very low resistance, you defo have a short. Then you just have to run the wiring like you're running the bowel of a dog (on the operating table) that has swallowed something it wasn't supposed to.
    • Hey guys, need help figuring out why my driver side (RH) fuse 15amp keeps blowing. The Driver Sides Headlamp is out, i replaced these a long time ago with LED ones that were working for 1-2 years. Now, the driver side light is out and i traced it back to a broken fuse. I replaced the 15 amp fuse in the engine bay and as soon as i flip the headlight on, it blows the new fuse. Any idea what's going on?
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
