I am not sure if that is a pic of the dash fuse box but just incase it is here is the translation:
Dashboard Fusebox
Left Column, top to bottom: Right Column, top to bottom
10A – Rear Wiper 10A – Shift lock
10A – Anti-stop 10A – A/T control
10A – Starter Indicator 10A – Air conditioner
10A – Room lamp 10A – Engine control
10A – Stop lamp 10A – Air bag
10A – Electrics 20A – Blower motor
10A – Engine Control 20A – Blower motor
10A – Hazard lamp 10A – Audio
15A – Fog lamp 15A – Cigarette lighter
10A – Turn signal 20A – Front wiper
10A – Meters 10A – Mirror de-fogger
10A – Electrics 20A – Rear de-fogger
Note that the engine bay fuse / relay box has a fuse key printed on the inside of the cover in english.
Going by rows, starting at the top left:
lights - 5A
Stop lamp - 10A
defogger - 20A
fuel pump - 10A
meter - 7.5A
????/ "bueatron" - 15a
front cigar lighter - 15A
aircon - 7.5A
NEXT ROW
fog lamp - 15A
room lamps - 7.5A
horn - 10A
ST Signal - 5A
engine and transmission - 7.5A
wiper - 20A
audio - 7.5A
heater - 15A
aircon - 15A
NEXT ROW (bottom)
Hazard lapms - 15A
tail lamp - 10A
Electrical parts (B)
heater seat - 7.5A
Engine control - 15A
indicators - 10A
Electrical parts ACC - 5A
mirrors - 10A
rear cigar lighter - 20A
Yeah, I was wondering about that. Could well be "pure tron". Never heard of it before! :D
couple of other things I wasn't sure about:
ST Signal? That mean indicators?
and electrical parts (B)?
And I never knew there was a rear cigar lighter in a skyline!?
:confused:
:confused:
If we take a look at B-Mans details under his avatar, we'll find that he in fact deosn't drive a Skyline... but a Y31 Gloria... hence the rear cigar lighter and electrical parts B.
Yep, it says ピュアトロン (pyua toron - "puretron")
And Rezz is right on the money, it's an Air Purifier/Ioniser... My R33 GTR actually has one on the rear parcel shelf between the two rear speakers...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
