Rare Work Wheels 5x114.3 17x8 +5 17x9 +10, R33 Rocker Cover Gasket Kit, R33 Gtst Ngk Iridium Spark Plugs, R33 De-cat, R33 Gtst Front Brake Pads.
hey guys i just sold my r33 and don't need these parts anymore.
not sure on model of these but they are rare work wheels 17x8 +5 and 17x9 +10. rear tyres are gone but fronts can still be used 205/45r17. pretty decent condition considering age with jsut abit of gutter rash on 1 rear wheel: $1500ono
R33 gtst rocker cover gasket set with left and right rocker cover gaskets (RHS: 13270-58S11 LHS: 13270-58S01) and x5 half moon plugs (11051-58S00). bought new from nissan for $102.00 which is pretty much the same as the one from kudos motorsport: $90
New R33 GTST NGK Iridium spark plugs x6. model number is: BKR5EIX-11. Recommended for stock/ish r33s. could fit other models but check the ngk website first: $70
used R33 decat pipe which looks like a cat. has dent as seen on pic and one on the otherside in the same place. does not effect performance at all. 3" wide pipe: $60ono
New Maxxistop R33 front brake pads: $50
can post items at buyers cost and according to weight otherwise picup is in hoppers crossing, vic.
do not low ball me as some of these prices are pretty cheap already. call me on 0432454387.
thanks
yeh they kinda do but they aren't as work rezax have less spokes and are spread out more. plus these have "rs by elbe" on the centre caps.
i'm also gonna drop the price to $1200 as i need them gone now since i have got a 180 to pick up next week!
also price drop on:
gasket kit $80
iridiums $60
need this stuff gone guys!!
i also have a good condition standard turbo back exhaust that came from a gtst 33 series II minus cat. when i was putting an afermarket exhaust on on of the nuts rusted pretty bad and wouldnt come loose so the guy welded it off lol. can still be used but u'll have to reweld it btu tis not big deal. will let it go for $50firm
Edited by jakez88
pretty sure .. going by offset, sizes and spoke design
center caps are pretty generic thru all that type of rim from Work
pretty sure they are Work Stich Mesh
http://i142.photobucket.com/albums/r102/cr...e0031Medium.jpg
would fit awesome on a 5studded R31 coupe. great price.
been getting alot of offers for the wheels so i will bring the price down to $1100. do not pm me anything lower then that otherwise i'll just ignore it. first in get em.
should also say that the front tyres are potenza GIII's with 50% tread on them although one has a nail in it so they pretty much need new tyres all round unless ur willign to repair it.
$1000firm for the wheels!!!!!!!!!
need these gone by next week!!!!
Edited by jakez88
sorry guys. wheels are sold pending payment!
although i'll let you know what happens.
r33 gtst front brake pads still for sale~! $40
Edited by jakez88
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
