pipster11 Posted March 16, 2010 Share Posted March 16, 2010 hey guys got my 34 4 pots ready to go on an i was just thinking, can i put the stock 2 pots on the rear? i know of a tracked 31 that has 32 fronts on the rear (i think) so would i be able to swap my 2 pots to the rear? anyone tried this before? any success? thanks Tom Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/ Share on other sites More sharing options...
pipster11 Posted March 16, 2010 Author Share Posted March 16, 2010 sorry, should add that the 31 is a hr31 not adm 31 Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5136934 Share on other sites More sharing options...
M I K E Posted March 16, 2010 Share Posted March 16, 2010 i wouldn't, the brake bias would be up shit creek Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137021 Share on other sites More sharing options...
QWK32 Posted March 16, 2010 Share Posted March 16, 2010 i'm sure you find that the mounting points for the rear will not accommodate a front calliper. you will also probably run into issue's finding a suitable rotor that will fit the offset required for the calliper, and also have the deeper hub for the handbrake shoes. i would also think that by putting a set of fronts on the rear you will probably stuff up the brake bias. if your after a cheap upgrade for the rear just get a set of R32GTR or R33GTST ones, they are a lot more common that a set of R34GTT rears would be. Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137022 Share on other sites More sharing options...
pipster11 Posted March 17, 2010 Author Share Posted March 17, 2010 i'm sure you find that the mounting points for the rear will not accommodate a front calliper. you will also probably run into issue's finding a suitable rotor that will fit the offset required for the calliper, and also have the deeper hub for the handbrake shoes. i would also think that by putting a set of fronts on the rear you will probably stuff up the brake bias.if your after a cheap upgrade for the rear just get a set of R32GTR or R33GTST ones, they are a lot more common that a set of R34GTT rears would be. yeah but if you think about it gtst rears are 297 (fronts are 296, if i'm remembering correctly) and the gtst (or gts25t) rears are 2 pots too i'm upgrading to 4 pot fronts so moving the 2 pots to the rear should help ballence i'll contact the guy running the front on his rears and find out if he is still retaining the stock handbrake so for the moment it seems like a no go, i shall delve deeper Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137080 Share on other sites More sharing options...
M I K E Posted March 17, 2010 Share Posted March 17, 2010 (edited) i'm upgrading to 4 pot fronts so moving the 2 pots to the rear should help ballence it doesn't quite work like that though. the last thing you want is to reduce the braking force to the fronts by increasing the size of the rears to something that could throw out the front/rear bias percentage (bmc can only dislplace so much fluid) nothing wrong with just upgrading the fronts and leaving the rears though, as most of braking force is through the front wheels as said above, just get the rears from a 33 gts-t and save stuffing around Edited March 17, 2010 by M I K E Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137115 Share on other sites More sharing options...
dirtyRS4 Posted March 17, 2010 Share Posted March 17, 2010 (edited) it doesn't quite work like that though. the last thing you want is to reduce the braking force to the fronts by increasing the size of the rears to something that could throw out the front/rear bias percentage (bmc can only dislplace so much fluid)nothing wrong with just upgrading the fronts and leaving the rears though, as most of braking force is through the front wheels as said above, just get the rears from a 33 gts-t and save stuffing around This is sillyness. If you want to do the rears use r33 gtst. If not as Mike and qwk32 have said just leave the rears as is and upgrade fronts. Buy decent pads, adr braided lines, slotted rotors and upgrade bmc - end of story. Most people do this for the visual aspect and there is no real proof this upgrade is better than a well setup stock set of brakes. Going better like Brembos wouldnt be justified on your rig atm. Watch low pedal position and handbrake issues. Use the search function and read brake threads by other members for more troubleshooting info. If you are after a excellent jap pad and quality brake products I recommend Acre. As I can swear by their products for daily driving. Edited March 17, 2010 by dirtyRS4 Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137171 Share on other sites More sharing options...
KiwiRS4T Posted March 17, 2010 Share Posted March 17, 2010 yeah but if you think about it gtst rears are 297 (fronts are 296, if i'm remembering correctly) and the gtst (or gts25t) rears are 2 pots tooi'm upgrading to 4 pot fronts so moving the 2 pots to the rear should help ballence i'll contact the guy running the front on his rears and find out if he is still retaining the stock handbrake so for the moment it seems like a no go, i shall delve deeper Never mind delving ...just take your wheels off and have a look - they won't fit. Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137324 Share on other sites More sharing options...
garetb16 Posted March 17, 2010 Share Posted March 17, 2010 also, everytime you touched the brake pedal you would lock up the rears. Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5137958 Share on other sites More sharing options...
stageaharts Posted March 17, 2010 Share Posted March 17, 2010 33/34 rears share the same caliper/rotor combo if I remember correctly, fronts share the same caliper internally (With longer mounting arms to the hub) but a different disc size. 33 rears can be had for a (relative) pittance, as everyone loves the brembo brake upgrade, and there are always plenty of 33 GTS-T's wrecking. I would go for the 33 rear set-up if you really wanted to double the amount of pistons. I can attest to the rears being a direct bolt up to S1's, I'm sure they would be similarly easy to bolt on to S2's. I got my front and rear 33 set-up with Calipers/Pads/Rotors (Pads & Rotors near new) off of a rolling part-out 33 GTS-T (defected) for $380. Start searching the classifieds Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5138474 Share on other sites More sharing options...
pipster11 Posted March 17, 2010 Author Share Posted March 17, 2010 yeah i'll just leave it maybe i'll redrill the rotors and put the old 2 pots on my 31 got my 34 fronts with pads, lines and rotors for $400 i'll see how they go for now then just gotta find some metalcast paint Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5138661 Share on other sites More sharing options...
pyro-ns Posted March 18, 2010 Share Posted March 18, 2010 This is sillyness. If you want to do the rears use r33 gtst. If not as Mike and qwk32 have said just leave the rears as is and upgrade fronts. Buy decent pads, adr braided lines, slotted rotors and upgrade bmc - end of story. Most people do this for the visual aspect and there is no real proof this upgrade is better than a well setup stock set of brakes. Going better like Brembos wouldnt be justified on your rig atm. Watch low pedal position and handbrake issues. Use the search function and read brake threads by other members for more troubleshooting info. If you are after a excellent jap pad and quality brake products I recommend Acre. As I can swear by their products for daily driving. upgrade bmc and get a bmc stopper Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5140402 Share on other sites More sharing options...
KiwiRS4T Posted March 20, 2010 Share Posted March 20, 2010 When i fitted the GTT brakes I found the master cylinder worked fine but I see that some people have replaced it - presumably to reduce the pedal travel (although increasing the effort required). My S1 has a BM50 - what are peope using who have upgraded and from which vehicle are these available (or have you paid the brand new price)?? Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5141868 Share on other sites More sharing options...
dirtyRS4 Posted March 21, 2010 Share Posted March 21, 2010 (edited) When i fitted the GTT brakes I found the master cylinder worked fine but I see that some people have replaced it - presumably to reduce the pedal travel (although increasing the effort required).My S1 has a BM50 - what are peope using who have upgraded and from which vehicle are these available (or have you paid the brand new price)?? I bought a cusco new at around $150 (Part no: 232 561A). Pedal feel was higher, less spongy and more responsive, but i had a full overhaul to stock brakes so hard to tell (comparing GTT fronts.) Dont know about using second hand stuff here (10-15 years old) but a GTT/GTR uses a BM50 and GTST uses a BM44. Brembos are BM57 and it seems that a 300ZX BMC uses that same bigger cylinder diameter - 26.9mm vs 25.4mm respectively? Edited March 21, 2010 by dirtyRS4 Link to comment https://www.sau.com.au/forums/topic/312233-riddle-me-this/#findComment-5142824 Share on other sites More sharing options...
