I'll get to the point. Series 2 ECR33 RB25DET. HKS Actuator installed and tuned to 0.73bar. Can the boost solenoid be removed and the hoses from the solenoid be joined together.
What problems would i get if this is done? If none, then it's fine.
Thanks.
https://www.sau.com.au/forums/topic/312235-boost-solenoid-question/
Yes and nothing
it is my understanding that it only controls the high and low boost, basically like a switch
its off until the ecu sees the rpm at a given rate somewhere around 4500rpm as well as throttle position
the ecu then sends the signal to compete the circuit witch changes over the solenoid to high boost
Most after market EBC if not all do away with it anyway.
Reason for asking is that my HKS turbo has a nipple and a hose attached from it to the hks actuator hence i have no idea what to attach to the factory boost solenoid. If it can be removed then i'll gladly do it.
Thanks for the reply.
Edited by teng
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 馃槈. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 馃槏.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 馃檹 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 馃槈. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 馃槏 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
