For a mates Khanacross Hack -
Don't want to over capitalise with some $70 Strut Inserts, and rear coilovers are actually expensive even for KYB or something equally average.
Anyone know what weight the standard oil is for front and rears (in this case an MR30, but I suspect it would be pretty standard across the make).
Cheers.
Daewoo
https://www.sau.com.au/forums/topic/312240-standard-shock-oile-weight/
Cheers.
Daewoo
Workshop manual is no help - just says 'Nissan genuine strut fluid or equivalent'. Perhaps try an auto store or Nissan.
JH
put it on some scales and see what it reads??? jk
Nobody likes a smart arse... actually, I do, :lol:
I assume it is about 270g, as these is 270mL in each strut... so by not running ANY oil, I could lightweight the car by 1/2000th of a tonne.
Full Race...
And for other respondents, thanks JH. From my Rally forum, a guy said he thinks standard is SAE15. So going up to 20 will stiffen the old girl up a bit...
Cheers,
Daewoo
Try Auto fluid to 40 grade motor oil depending how stiff you want them.
A mate drills a hole in the side and drains them, fills them with auto fluid and brazes up the hole.
If you want I can ask him how much.
Cheers, D
Cheers, D
Hi Dennis,
With the fronts you don't need to drill, you just pull them apart and fill them with higher weight oil. ATF seems to be about 20W... you really should use the correct weight fork oil or hydraulic oil, but ATF is available and cheap...
engine oil at 50W when warm would be too stiff for dirt work, and I would suggest too stiff for track work as well, unless you are are running huge springs...
For the rears, I usually drill a hole in the base, drain the oil, refill, and then tap a thread and bolt with an o-ring... In this case, we both have some cheap gas rears to use...
Cheers,
Daewoo
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
