ok im gona break it down nice and simple for ya.
DO NOT WASTE MONEY SAVE FOR TURBO / WAIT TILL OFF Ps
but i know its hard to do so when young / on Ps (personal experience)
1. Exhaust 2.5" catback + extractors if you want them..
2. Pod filter / heat shield
3. Cut hole / feed a cold air intake
4. Get a nice body kit if you want.
5. Wait till your off Ps
Mines pulling 123rwkw with just a cat back / pod. Helps to have a healthy engine. Also manual.
get a good set of lightweight rims + good tyres (dont waste money on shitty tyres) go get good ones!!
get a set of coilovers + whiteline sway bars etc etc
simple 2.5" catback exhaust with a nice muffler (dont go cheap on teh muffler) + extractors if u really want but if ur going to turbo it dont as turbo's dont use extractors...
then jus get the basics, tinting, some nice speakers maybe and jus save save save for a turbo car/turbo your own car :D
The best thing you can do to your non turbo engie being a P plater is go out and get some essentials (carby cleaner-throttle body cleaner, lube spray, electrical connector and wire cleaner, WD40, Wire dryer ETC ETC ETC)
Buy some automotive tools if you dont have some etc etc
-Change air filter
-Change oil filter
-Change fuel filter
-Change engine oil with an oil flush (try changing to a full synthetic such as nulon which is about $150 less than a redline oil usually $50 at automotive stores)
-Change gearbox oil
-Change diff oil
-Change brake oil
-Change Clutch oil
-Change coolant with a system flush before
-Total fuel system cleaner is 28 times more concentrated than a injector cleaner so spend your money there and it will do the best job on the place you cant reach without pulling an engine apart
-Clean throttle body (spray the hell out of it with carby cleaner and wipe down)
-Clean the AAC (IACV) (spray the hell out of it with carby cleaner and wipe down)
-Clean the Cold start valve
-Change sparkplugs
-Go around and pull all your electrical plugs out, from headlights and brake lights - throttle position sensor and O2 sensor. Clean all conections with an electrical contact cleaner and wire cleaner on the wires in the engine bay such as earth wires (will be very time consuming )
-Clean all sensors E.G. your radiator sensors may be gooped up if oil has ever come into contact with the coolant, O2 sensor can become conjested with carbon so carby cleaner can get rid of that
-Change all your relays and fuses that are not working (using a test light you will see if there is a current passing through or not)
-Test all your sensors with a multimeter providing you know what volts, resistance etc you are looking for. This will determine if any sensors are dead or not up to scratch (Read next line for other option)
-You can also have Nissan diagnostics scan tool pluged into your car (or even buy the CD and plug online) too read out any errors that may be present and you can also have your timing set, air/fuel ratio mixtures adjusted and a few more things (this is best as it will read all sensors too and give accurate readings). This test is really the last thing you will have too do as it will read your whole car and you will be able too tell things like the volts in your battery or even shut down the spark too a cylinder. When it reads 'error code: 58' you dont have any errors in your car and its running fine.
Once all that is done if you are getting the ECU scaned the tool can reset it. Once reset take it out for a nice calm drive and it will load all information from the car back up onto itself. The car will feel new and will definatly give you some power back, hopefuly get you all the way too stock power output
All up you could spend $500 here depending on what tools, etc etc, inc the Nissan diagnostics scan tool which is about $250 or you can get it done at a performance shop.
Oils and filters and spark plugs are common things and you wont pay more than $400-500 if you buy all you aerosols and oils from nulon.
And asuming you do all the cleaning and (all this is very easy and a w/e can be the best time to complete all this) taking apart of small electricals and parts you will be doing labour youself. I can see it cost all up $500-$1000
THIS IS THE BEST THING YOU CAN DO TOO YOUR NA!!!!!!!!!! so much easier than a turbo and you will gain power and also piece of mind that your car it a lot more reliable......
^^^^^^^^^^^^^^^^^^^^^^^^^^ Thats the best you can do but after that i suggest
Coilovers (height and camber adjustable)
Links (adjustable re enforced Nismo ones)
EBC brake pads and rotors (They do non turbo skylines :down: )
Whiteline sway bars and links
Change everysingle bush on the car too Superpro nolythane bushings
Kakimoto 2.5" catback then have a exhaust shop custom make a cat and front pipe too bolt onto DKNE extractors
Falken 452 tyres or Toyo Proxies T1r (best road going tyre with very soft compound for light track work)
Thats like a little $10,000-$20,000 worth of stuff there depending on what brand you use
Hope thats enough too keep you busy
Simply just too big for a stock engine doing everday driving
then jus get the basics, tinting, some nice speakers maybe and jus save save save for a turbo car/turbo your own car :down:
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
