http://cgi.ebay.com.au/GKTECH-SS-R32-R33-S...=item5884a5677c
http://cgi.ebay.com.au/NISSAN-SKYLINE-R32-...=item2ea80a6c50
I currently have an aftermarket dump pipe and 3" Catback exhaust looking at gettin the front pipe to make my exhaust 3" Turbo back what is the best choice out of the 2 examlpes i have given?
https://www.sau.com.au/forums/topic/312321-exhaust-flex-pipe-yes-or-no/
It's not a question of performance.
Same shit.
You NEED a flex pipe to absorb movements in and around the exhaust system.
This eat's up stress that would otherwise be put on exhaust manifolds, exhaust mountings and so on.
id go with the cheaper one with the flex joint aswell.
and with all cheapy stuff the jigs they use are often not rite. so with the flex you have that extra margin for error. just make sure you have the g box exhaust hanger fitted..
Indeed it could pose a problem.
Get things hot enough, they can warp and so on with too much weight.
Could warp flanges and so on. Extra stress on manifold bolts and the like.
I've seen a turbine housing actually twisted due to similar issues with heat/weight (was circuit, 400rwkw+ setup though)
It does happen, my Exhaust hsg warped and I had to replace the hsg
Does any one want to group buy in it??? Ill also purchase one and gaskets to suit if any ones keen, Im going to replace my stock Nissan exhaust and Add a 3inch kakimoto racing pipe behide This GKTECH RB25DET Front/Dump pipe http://www.gktech.com.au/front.asp?pid=11&...uctID=R323-FRDU
Edited by HoWiE_Au
^^ about that. i have no gbox to exhaust support on my system. its a stainless turbo back with no flex pipe.
can it be a problem?
i would have one put on there, my dad's snapped off from the back of the turbo!
Edited by mark660
Lol, saw them on ebay and decided on buying 2 for the RB26dett
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWNX:IT
also found cheap same-priced 3" turbo dump pipes, so paid for 2 of those as well.
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...em=350324770735
Will merge the 2 gktech's into 1 3" outlet, inlieu of cat-converter pipe, to mate up to the 5zigen cat-back I have
yeh - whys that - wont they work (ie bolt on) ?
I thought they did. . .
or are you saying they are crud.
to be used only a few times per yr on a R32 track-sedan
the rb26 engine will be rebuilt in a couple of years time after some Mallala sessions, and go into my Stagea
  • 4 weeks later...
Ive bought a GKtech front split pipe and put my exhaust on overall it feels like i cant get my auto to tramp it as much down low it could be because im not catching the revs properly with my right foot. But about 3 grand till red line i do notice a fair bit more pull (Note i'm running a stock rb25 turbo) Just a lame arse question what size are these baby snails are the a T2 or T25 size or something all i know is there bloody small compared to my T04e i have in the cupboard. Im not game enough to put on my Ebay t04e snail on my car lol
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
