R32 Gtr Rims On R32 Gtst
How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
By DraftySquash · Posted
Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing -
Given it is temporary, I bought a cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
