  • Replies 128
I too am keen to find out the P:W but not for lawful reasonings.
I believe insurance co's can refuse to cover you on anything illegal, its just a matter of whether they will or not, or if they actually know about this or not.
certian insurance compaines will cover p platers in an r33, however come accident time they will not be covered plain and simple.
You CANNOT use a weighbridge to weigh the car, and you CANNOT use a dyno reading for power measurement.
well i dont agree with this one little bit. why cant you use a power measurment? im under the impression you can!
Originally posted by SmoothLine
Weighbridge means nothing... its the unlaidened factory stated weight they go by...
Bit unfair but its just the standard.
we know this smooth... this has been established... as explained we want to weigh our cars FOR US! lol so we know our own power to weight :D
yeh its sumthing like that, i got that tick for driving the R34 GTR....Actually it wasnt listed on the list of high powered vehicles, but the curious officer that oulled me over, went home and actually researched on the vehicle ringing back 2 days later saying if i was caught again 2 year loss of my license.....:P..scary thought it is...he also said that if i had an accident that insurance would not cover it.....so now im stuck with driving a '01 SR2 Laser, but i still got the GTR, and im 18, it was my first car :D
man thats crap... u could always lend it to me til u gte off ya Ps :P or drive my 32 in the mean time as its under the limit :P
hehe no worries mate, but at the mean time my dad loves driving the thing, ive got a suspicion that he bought the car for himself and used me for an excuse to my mum...lol..as he is a car freak...
well we r picking the car up tomz, as it is all ready with all the mods that have been fitted into it, and hopefully if it doesnt rain will be at calder park this friday night....:
Originally posted by Baileylsd
hmmm so u could by a skyline r33 gts, then get top secret to drop in a rb26 with 600kw
and u couldn't get a fine, lol what a stupid law
the look on the cops face would be priceless
p/w = rated power of the ENGINE / tare weight of car
thus dropping in this engine would mean that you would have 206 as this figure. odifications not included as its the power of the enging as it came out of the factory.
in the same way it is the tare weight (which is the dry mass by definition) and so if your car is heavier then bad luck.
so basically, get a just-legal car (ie r32gtst) then drop the weight and increase the power and you are laughing all the way to the end of the 400m line...
Turboed R32/33's Skylines are on the banned list of cars able to driven on the road by P platers, they dont come under the power to weight rule as far as I know, RTA have a list of cars unable to be driven by P platers, then if your car is not on that list the power to weight rule applies. you have to go into Vic Roads if in Victoria to get the list they dont put it on their website. dont know about other states.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
