  • Replies 128
It is all to do with the Power/Weight ratio, here are the figures for the R33:
RB26DETT Engine – 137kw/tonne
RB25DET Engine – 127kw/tonne
RB25DE Engine – 2 door 110kw/tonne
RB25DE Engine – 4 door 102kw/tonne
RB20DET Engine – 109kw/tonne
RB20DE Engine – 73kw/tonne
Here is the info from the Vic Roads website:
High Powered Vehicles
All probationary driver licence holders are restricted from driving a high powered motor vehicle on a highway. A high powered motor vehicle is defined as a motor vehicle (not a motor cycle or motor trike) which:
has a power to mass ratio which exceeds 125 kilowatts per tonne; or
has an engine capacity which exceeds 3.5 litres per tonne of the unladen mass of the motor vehicle.
* Information regarding high powered vehicles can be obtained by telephoning VicRoads on Tel: 13 11 71
If you have a slightly heavier than normal R33 GTST you will be ok.. according to the law.
no nothing can happen. Ive been in this situation had a talk to the officer who was trying to get me. Because there is no official records of skyline gtst of there power to weight i went to nissan and asked them and they said the only way to get them would be from nissan japan. So the officer couldnt do anything about it. Thats the only trouble ive had with the law trying to stop me once. Other times they dont know nothing about the car, such as calling a front mount intercooler a radiator and saying my stock blow off valve is illegal because no turbo cars have ever come out with blow off valves? weird...
does anyone have any experience in getting dcked for this...do the cops know that a R33 GTS-T is going to be over...and is it possible to get your car detuned to run under the weight and have a signed machanic sign it or something...is there any way around this rule...i'm about to buy my first car and i want it to be an R33 GTS-T but i don't want to buy it and have it sit in the garage for 3 years while i drive some sh*tbox
if u do get caught do u just keep getting fined or wats the penalty...is there any way to legalise an R33 GTS-T using a machanic to detune the car...would this be good enough...and do the cops know wat to look for/know the specs of the R33 GTS-T
The power to weight laws were introduced months before i got mu p's many years ago, I obeyed them and managed to drive cars that were faster than the typical illegal cars (like 6cyl cortinas and v8 commodores), without any undue problems from the police. If you drive a turbo skyline on your P's you are asking for it.
A naturally aspirated skyline is plenty fast for an inexperienced probationary driver, and shows maturity in accepting this fact.
Don't get me wrong, I deal with many probationary drivers and share their enthusiasm in the world of high performance cars, but this is real life not NFS.
At the end of the day some police will know enough to book you for power to weight and some will not, on the other hand some cops will see 'Turbo' and dick you anyway.
This has been a community service announcement brought to you by some old intoxicated tool that is taking a break from modifying his turbo skyline in his garage!!!!! :):D:D
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
