Will Usdm Vortech Fit Our V35?
Just wanted to see if anyone knows if the US vortech kits will fit on our right hand drive v35's? And if so anyone know of any sydney based workshops that have installed them.
The part number they are selling over there is exactly the same part number as the ones capa are selling for the 350z. Ive emailed capa but still waiting on a reply. Just a bit concerned about the intercooler and intake piping matching.
I will be just getting the tuner kit and supplying my own fuel upgrades and engine management so tuning shouldnt be an issue as on the vortech website it just states for international buyers the kit may require custom tuning.
Appreciate any input.
Cheers
Edited by robbo33
Cheers
I'm guessing it would fit. But best wait until you get a reply from "capa"
just make sure that the vortech kit is complete and made for your engine spec (S1 or s2)...
When I was in Dubai, I almost bought my friend's kit and did list it for sale on this forum with no bites. I eventually gave up on buying it off my friend as I didn't know of any workshop that could do the install and obtain relevant approval...spewing now, should have done it!
good luck with ur supercharging fun....
I remember when I reading back through one of the Zed forums, there was a post with heaps of info. It said you can fit the kit onto a V35 but it's not a completely direct bolt-in, some modifications are required either on the frame or with the piping, I don't remember which. There is also a big difference in the frame between VQ35DE and Rev.Up motors, so make sure you buy the right kit for your engine.
 Share
    • People still have Skylines? I thought they're non-existent now.
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
