I can confirm the Gibson R32 GTR will be there. Group A
http://www.vhrr.com/phillip_island.htm
Saturday & Sunday
Group A & Group C Touring Cars 5 Laps 12.10 pm
Group A & Group C Touring Cars 6 Laps 4.10 pm
PI_2010_Event_schedule_Fri_Sat_Sun.pdf
Was a great day, I know a few of the drivers and managed to get some pics of my son driving the DR30. ;)
I saw a couple of GTR's including 3 R35's, but no Sau stickers. Who else made the trek down?
Awesome photos.. especially the DR30.. didn't realise that was floating around still :(.
It was locked away since its last race, Hadn't been started in nearly 20 years apparently.
Still had a lot of the original race parts like asbestos brake pads, you cant get closer to original race spec than that.
Thats correct. at least now we can see that the GIO car is the hands of a very good steerer. though im not sure what happend in the last race on sunday. he bogged down off the line, then miss shifted going from 1st to 2nd, then i think he had an off around the southern loop because when he came back into view around the back toward the hairpin, he was dead last!
it was awesome watching Terry carve his way through the field in the last race! he started at the back because he had a fuel pick up issue in the morning race (of which he was dominating!). in just six laps he managed to get from the back, up to 4th place (from memory).
In the Friday qualifying session Terry clocked a 1:44.9819! thats one for track guys who are going to phillip island in april for the wrx club day to think about... :blink:
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
