Does anyone know when Terry Ashwood is running his GTR?
Have never been to a Phillip Island Classic so am unware of how often and when each car races.
Phillip_Island_Entry_list_2010.pdfFetching info...
Edited by willL
https://www.sau.com.au/forums/topic/312385-phillip-island-classic-2010/
  Takahashi GTR said:
I can confirm the Gibson R32 GTR will be there. Group A
http://www.vhrr.com/phillip_island.htm
Saturday & Sunday
Group A & Group C Touring Cars 5 Laps 12.10 pm
Group A & Group C Touring Cars 6 Laps 4.10 pm
PI_2010_Event_schedule_Fri_Sat_Sun.pdfFetching info...
Was a great day, I know a few of the drivers and managed to get some pics of my son driving the DR30. ;)
I saw a couple of GTR's including 3 R35's, but no Sau stickers. Who else made the trek down?
  Sarumatix said:
Awesome photos.. especially the DR30.. didn't realise that was floating around still :(.
It was locked away since its last race, Hadn't been started in nearly 20 years apparently.
Still had a lot of the original race parts like asbestos brake pads, you cant get closer to original race spec than that.
Thats correct. at least now we can see that the GIO car is the hands of a very good steerer. though im not sure what happend in the last race on sunday. he bogged down off the line, then miss shifted going from 1st to 2nd, then i think he had an off around the southern loop because when he came back into view around the back toward the hairpin, he was dead last!
it was awesome watching Terry carve his way through the field in the last race! he started at the back because he had a fuel pick up issue in the morning race (of which he was dominating!). in just six laps he managed to get from the back, up to 4th place (from memory).
In the Friday qualifying session Terry clocked a 1:44.9819! thats one for track guys who are going to phillip island in april for the wrx club day to think about... :blink:
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
