i got a real gaming pc for sell
Intel Q9550 Quad 2.83ghz 12mb cache(overclock to 3ghz to fully use the graphic card)
Asus Triton CPU FAN
Gigabyte EP45T-Extreme
Corsair 4GB DDR3 1600Mhz
Corsair Extreme 60GB Solid State HDD
Asus 896MB GTX-275 vcard
2 x 320 HDD
22 Speed Pioneer Dual Layer DVR-RW
Antec 900 Case
Thermaltech 750 Power Supply (Cable Management )
LeadTek DTV2000 TV Card
looking for $1200 or give me offer :P if anyone interest can pm me or text me on 0411268935
https://www.sau.com.au/forums/topic/312403-gaming-pc/
notice Price drop due to 60GB solid state sold
new price $950 i will add another 160GB seagate and a 300GB HDD freee
or $950 with 30GB Corsair Extreme X32 SSD
Asus Triton CPU FAN
2 x 320 HDD
Antec 900 Case
https://www.sau.com.au/forums/topic/312403-gaming-pc/#findComment-5149373
ok last chance $850 buck for all this
also any type of window u name it i will install for u
Asus Triton CPU FAN
160GB HDD - Sata
300GB HDD - Sata
2 x 320GB HDD - Sata
Antec 900 Case
https://www.sau.com.au/forums/topic/312403-gaming-pc/#findComment-5158143
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
