ssshonky Posted March 18, 2010 Share Posted March 18, 2010 Ok to cut a long story short, I did have a look thru the various wheel threads but they focused more on the wheel offset etc Vs actual tyre fitment. the 215 50 17 size that the Stagea has now is limiting our choice of replacement tyre. Has anyone actually FIT a 225 45 17 to their C34 S2 , ours has the "autech" rims not sure if they are any different than others. I just dont want to order the tyres then get em here and they dont fit. Anyone shed any light on this? Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/ Share on other sites More sharing options...
CL11QE Posted March 18, 2010 Share Posted March 18, 2010 im just waiting to hear back from tates about a new set of tyres, gave em my size which is the 215 50 17.... Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5140692 Share on other sites More sharing options...
CL11QE Posted March 18, 2010 Share Posted March 18, 2010 where are u located? Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5140695 Share on other sites More sharing options...
dirtyRS4 Posted March 18, 2010 Share Posted March 18, 2010 (edited) Ok to cut a long story short, I did have a look thru the various wheel threads but they focused more on the wheel offset etc Vs actual tyre fitment.the 215 50 17 size that the Stagea has now is limiting our choice of replacement tyre. Has anyone actually FIT a 225 45 17 to their C34 S2 , ours has the "autech" rims not sure if they are any different than others. I just dont want to order the tyres then get em here and they dont fit. Anyone shed any light on this? Stock Autech Rims are 17x7 + 30 front 17x7 + 20 rear. I run 17 x 9 +20 Wedsports SA90s with 235 45 17 with RE001s. Had floating spaces but f**ked them off. Needed nismo long bolts because of not much thread. Basically R33 GTR offset. I will not go up to 18s for daily driving only for show. Duncan runs these exact rims with Feds as far as I know. Fitting these will be close to perfect, just dont rotate front with back because they are offset specific. You dont want to strech your tyre either, so 225s are fine for 7s. If you are from WA give chuckie a pm regarding Hankooks. Ive heard Nittos are also good and much cheaper. Buy a good set of tyres. Mine cost more than my rims but it has payed off in the long run. Edited March 19, 2010 by dirtyRS4 Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5140740 Share on other sites More sharing options...
BoostedBarge Posted March 19, 2010 Share Posted March 19, 2010 I'm 90% certain (can't confirm, not at home), that my Autech has 225/45/R17 tyres on it at the moment. Standard Autech rims (about to be replaced - horray!). Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5140889 Share on other sites More sharing options...
KiwiRS4T Posted March 19, 2010 Share Posted March 19, 2010 225/45 will fit as will 205/40, 215/45, Popular size seems to be 235/45/17 (like I have Potenza RE001) but you need 7.5 or 8in rims for those. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5140983 Share on other sites More sharing options...
SABBAi Posted March 19, 2010 Share Posted March 19, 2010 i run 225/45/17's on my 17 x 8 BBS's. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141015 Share on other sites More sharing options...
msports180 Posted March 19, 2010 Share Posted March 19, 2010 225/45 will fit, but you will pay more then for a 235/45 as its a very common size, i have 235's on my autech rims and they fit fine, bulge a tiny amount but you cannot feel it when driving hard ish. Id go the 235, can get em from $100 Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141179 Share on other sites More sharing options...
BoostedBarge Posted March 19, 2010 Share Posted March 19, 2010 I asked a tyre shop to fit 235/45s and they refused. They said they are illegally too wide to fit on the 7" rims. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141498 Share on other sites More sharing options...
ssshonky Posted March 20, 2010 Author Share Posted March 20, 2010 where are u located? Perth Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141885 Share on other sites More sharing options...
ssshonky Posted March 20, 2010 Author Share Posted March 20, 2010 225/45 will fit, but you will pay more then for a 235/45 as its a very common size, i have 235's on my autech rims and they fit fine, bulge a tiny amount but you cannot feel it when driving hard ish.Id go the 235, can get em from $100 So if your 235 fit the 225 should be fine yeah? I just don't wanna order tyres then get stuck when they don't fit Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141886 Share on other sites More sharing options...
ssshonky Posted March 20, 2010 Author Share Posted March 20, 2010 I'm 90% certain (can't confirm, not at home), that my Autech has 225/45/R17 tyres on it at the moment. Standard Autech rims (about to be replaced - horray!). Could you confirm pls ? Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141891 Share on other sites More sharing options...
lachlanw Posted March 20, 2010 Share Posted March 20, 2010 i have 235 45s on my wheels . which were rs four s 17x7 +30 . i now have 4 front autech wheels ,exact same size . nothin wrong with it . can someone tell me why the fore mentioned tire shop wouldnt do this? Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141912 Share on other sites More sharing options...
BoostedBarge Posted March 20, 2010 Share Posted March 20, 2010 Unfortunately I was away with work and someone else took the car to the tyre shop for me. The tyre shop had ordered in some 235/45/R17s for me and then when they took the car in, they rang me and said that it was illegal to fit these tyres to a 7" rim. That's all I know... I'm away again, so can't confirm the tyre size that's on there now. I've asked the misses to check for me. She'll get back to me soon. I'm pretty sure they are 225/45/R17s and they are the tyres the compliance centre put on for me. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5141949 Share on other sites More sharing options...
KiwiRS4T Posted March 20, 2010 Share Posted March 20, 2010 225 will fit on a 7in rim. You can search online for fitment charts to confirm if you want. 235 will fit but are not recommended although i don't know about ïllegal" especially when I see some of the stupidly "stretched" tyres that some people have. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5142117 Share on other sites More sharing options...
msports180 Posted March 20, 2010 Share Posted March 20, 2010 So if your 235 fit the 225 should be fine yeah? I just don't wanna order tyres then get stuck when they don't fit Yeah they will fit easily. Ive never heard of them refusing to fit tyres before, a 265 sure but not a 235, the standard stagea size is a 225/50/17. Just being pedantic. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5142291 Share on other sites More sharing options...
JZZ20 Posted March 21, 2010 Share Posted March 21, 2010 I have stock Autech Rims (17x7) and the stock fitment as far as i know is actuallt 225/50/17 from factory, and is what I'm running. I have a slightly separate question for those with a 260RS.... What size wheels can I fit??? I have the bilstein struts and have lowered them as far as I can. It seems to me like 18x9 will not fit, so was thinking 18x8 +15 for the rear, and probably +25 for the front (matching up the stock offsets). Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5142463 Share on other sites More sharing options...
pintaline Posted March 21, 2010 Share Posted March 21, 2010 235/45/17 are illegal on a 7" rim, narrowest it can be legally fitted to is a 7.5" any good tyre shop should refuse to fit them to a 7 because they can get in shit if you get defected for it as they shouldnt have fitted it. i have 225/45/17 on my rs4s rims, apart from f**king the speedo reading due to the smaller rolling height, they fit perfectly fine. my speedo just reads about 9km/h under what im actually doing D. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5142529 Share on other sites More sharing options...
ssshonky Posted March 21, 2010 Author Share Posted March 21, 2010 I got told that 225 45 17 should be same rolling diameter as 215 50 17?? Was he full of shit? 235/45/17 are illegal on a 7" rim, narrowest it can be legally fitted to is a 7.5" any good tyre shop should refuse to fit them to a 7 because they can get in shit if you get defected for it as they shouldnt have fitted it.i have 225/45/17 on my rs4s rims, apart from f**king the speedo reading due to the smaller rolling height, they fit perfectly fine. my speedo just reads about 9km/h under what im actually doing D. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5142533 Share on other sites More sharing options...
KiwiRS4T Posted March 21, 2010 Share Posted March 21, 2010 I got told that 225 45 17 should be same rolling diameter as 215 50 17?? Was he full of shit?They will be near enough the same...a little bit smaller so your speedo will read a little higher. Link to comment https://www.sau.com.au/forums/topic/312502-225-45-17s-on-standard-c34-s2-autech-rim/#findComment-5142593 Share on other sites More sharing options...
