Ive never looked at the price of Willwood before but thought for sure they would be up there in price, definitely not that cheap, like thats easily affordable as a brake upgrade... I was almost expecting AP caliper prices...
thanks for posting that one....
Any details on the calipers? Maybe they are only 4pot calipers instead of the usual 6/8 in the other big brake kits. Still looks like and awesome budget upgrade for those of us with the standard brakes.
I use Wilwood callipers on my car... The callipers in that ad are the entry level cast 4 piston callipers, where as the ones I run are 6 piston Billet Superlight Callipers. I believe the 4 piston callipers wouldn't be much better than your stock ones, but the increase in Disc size would be worthwhile.
I have asked for more info about the calipers. As best I can tell from the photos they looks to be Forged Superlite calipers. These calipers are all 4 pot calipers, take a 330mm rotor and can range in piston area quite a bit.
http://www.wilwood.com/CaliperList.aspx?subname=Forged Superlite://http://www.wilwood.com/CaliperList....orged Superlite
The calipers with the 1.62" pistons would have a piston surface area similar to Brembo f40 calipers (53cm squared). Anything above that would put out the bias of the brakes by quite a bit. The small 1.38" calipers would probably have a piston area too small (38.5cm squared).
This is just best guess as far as I can tell. I will update once I am given some definite info.
Ckeck out this link re wilwood brakes.
http://www.arizonazcar.com/240sxbrakes.html
This is who I bought my brake setup from, except I purchased the 300zx kit. Awesome package for the money.
The only issue with the install, was having to get some longer brake lines made up.
Given the size of the calliper and rotors is much larger, I was surprised to find they actually turned out to be the same weight as the stock R33 GTS25t brakes they were replacing.
Don't worry about Roys post above... The quality of the Arizona Z car kits are awesome, and Dave is great to deal with - if you go down this path, you won't be disappointed.
Edited by Ryno
I was mostly referring to the ebay link. A few things...
If they are not telling you the caliper number or what model the Brembo rotor is for/off then its a bit of a gamble. The more typical Brembo rotor sizes are 324 or 332mm. I am sure they make 330 but would need to check what model car it is off and find out if its a 28, 30 or 32mm thick rotor, curved vane? Ditto what others have said you would want to make sure that the pistons sizes are correct for your car. Based on the price I would be assuming (another thing to check) is that the pistons sizes are the same, so you dont get the advantages / trend to go smaller on the leading piston for better pad wear and less rotor hot spots.
So thats the compilation of components questions, no doubt great value, and could be a good performing kit....but its a leap of faith without the answers.
The reason for my stay away comment, is Wilwood make calipers for many applications. Thats why they are great and so popular. But, that model of caliper is about the cheapest 4 piston caliper they make. These 4 pots are 30-50% of the price of the 4 pot caliper that you would generally be wanting in your kit. Effectively they are no different better then the std Nissan 4 pot caliper. You are basically changing calipers which is costing you money and limiting the range of pads you can run for no benefit
The Arizona Z kit is a much better bet. They run the nicer Billet range of Wilwood caliper (6 pot or 4 pot , makes no difference to me they are both nice calipers) They run a chunky, probably Nascar based rotor with curved vane and greater width then you get in majority of kids. So a much better kit, but still be concerned about the custom hat and the hardware they use to mount the hat and rotor. How do they stack up with some kms on them? Do they get noisy, slack and bang up the hats with some kms??? Its not a method i have seen before?!?!? They did still mount the rotor backwars in the mock up pics :)
So, as Ryno said, its only my opinion...and could be wrong. But the above is the thinking behind my comments, If Ryno can confirm he has put lots of kms on his setup and the hats have not become noisy or damaged at time of rotor replacement then they are great value. I still dont get why the Arizona kit spec it all together the way they have and go lug mount instead of radial...radial is better for so many reasons
I've seen the Arizona Z kit on two cars at Barbagello which is why I mentioned them. Kingcorps s14A which recently set an IPRA lap record, and Steve Myburgs very fast 550wrhp RB powered 180sx which I believe runs in the sports sedan category. I've previously pm'd Kingscorp and he advised that he has yet to change a set of rotors after about 2 or 3 seasons of racing. He informs me you can get them locally anyway.
None of these guys have problems under brakes, and in fact based on their various youtube videos, they seem to consistently outbrake or at the very least are on a par with their competition.
With the $A/$US exchange rate at the moment.....is there a better value brake package out there than the Arizona Z kit?
Edited by juggernaut1
From Arizona Z site:
Front US$1,395
Rear US$ 795
Total US$2,190
At say ~ 90 cents ex rate = A$2,433 plus delivery plus possibly customs duties and GST. Also their pricing may include local transaction taxes which may not be applicable to exports out of the US.
Would the rears be necessary? Its for a track r32 GTR.
Also I was referring to actually getting the kit on the car, seeing as its not a direct fitment. I've emailed the guy about it so hopefully he may have some insight.
Can't really answer your fitment questions......however,logically.....the rears may be necessary in order to maintain the correct front/rear bias via the caliper piston sizes with your stock bmc. That is the Arizona Z front/rear kit may be matched to suit stock bmc's otherwise you may end up with bias issues.
These are questions Dave at Arizona Z will surely be able to help you with.
Hey mate,
I have installed the Arizona Z car 300zx kit on the front of my R32. The kit bolts up directly, the only issue you will have is the front brake lines not being long enough. I got new braided ones made up for about $100.
The brakes cost me around $2000 Aus (incl shipping)... so add $100 for lines and $20 for fluid.
I have not purchased the rear kit yet, as they do not use the standard cable handbrake - as my car is a daily driver I wanted to keep this. Dave has almost finished his new setup for this though, which includes an additional small billet calliper mounted on the disc for the cable handbrake setup.
If you have any more specific questions on the install, I'm happy to help
Ryno
Thanks for that mate, for $2000 it seems like an excellent buy compared to the chinese stuff.
Have you tracked your car with these brakes? Do you think the rears will be necessary?
Yeah that was the same thought I had. I was actually looking at paying around the same money for R34 Brembo's, but these seemed like a much better buy.
I haven't taken the car to the track, but I'm sure they would be awesome. During the bedding in process, they were still wanting to lock a front wheel on the 10th stop from 100 kph.
I personally don't think the rears will be necessary, as the fronts do most of the work.
I also wouldn't worry so much about the possible brake bias change, as that is set by the Brake master cylinder anyway.
If I do go for the rear kit later on, it will mainly be for the look, rather than the performance.
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
