Hi all
Just finished my manual conversion on my R33 Gtst, the problem is that there is a ringing noise coming from the gearbox,Could this be a warn thrust bearing, Moving through the gears perfect.just that nosie.
Any ideas thats all i can realy think of
Cheers
https://www.sau.com.au/forums/topic/312537-ringing-noise-coming-from-gearbox/
Hi all
Cheers
Dropped your phone in there? :) Nah.
When does the ringing noise appear? Is it specifically while you're driving or only when you put the clutch in? Does is stop when you put the clutch in? Is it a slight grinding sound? (Like rolling a steel wheel on concrete.)
Answers to some of these q's will help diagnose your problem.
Hey mate,
Its fine while the car is not moving it is only when i start moving,when i put the clutch in the noise slowly disapears, the sound is Like rolling a steel wheel on concrete but a higher pitch no grinding noise
cheers
Possibly your throwout bearing in your clutch assembly. Although, you'll usually hear it when its just sitting, and when you put your clutch in, it will slowly disappear. If it's fine while you're sitting and in neutral, it could be slightly worn gear cogs, even just gearbox oil being low.
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
