Hey guys,
i don't have the skyline yet.
coming from overseas :D
and the r34 is going to be a 2door Trip tronic gear skyline
i know can change the gears without a clutch
but can i just say "ok skyline i dont want to change ears manually just change them for me" ??
cheers :rofl2:
https://www.sau.com.au/forums/topic/312597-trip-tronic-gears/
it has the normal P R N D 3 2 pattern... whilst in drive u can flick the gear knob over to the left hand side into a different slot and u push the knob downward to go up a gear and upwards to go down a gear ( i think.. i have a manual R34 skyline may be the other way round but im pretty sure thats right )
and no its only the V35 and R34 skylines that have the tiptronic mode in the autos.. all others (31, 32, 33 etc models) have the normal gear shifter as any other auto car has...
Edited by noely1
yeh first part is right,
first post was bit more helpful and sounded more realistic . umm yeh,
should be fine, i guess i can always call up my local nissan workshop
thanks for the help (: just gota clear that up
and im gettng a r34.
theres not much to understand mate, its a standard automatic car. simple as that, you can select Drive and off you go.
only difference is, if you feel like it, you can select a mode in which you tell the auto when to change gears rather than the computer doing it for you.
Tiptronic isn't really that flash - my R34 was tiptronic for the first 3 years I owned it. They're good gearboxes but as Silver GT said above, they're essentially just a standard automatic slushbox. It'll jump down to 3rd gear fairly quickly and you have to apply more throttle to get it to kick back a gear. Over 60kph it'll slip into 4th and stay there, unless you knock the lever across into tiptronic. Upwards changes up a gear and down changes down. It also won't let you change into 4th below 60kph until the engine has warmed up.
I ended up having mine converted to manual because it seems to suit the car much better.. mainly for the gear ratios. The auto 1st gear is pretty short - letting you take off pretty quickly, but then second gear is quite tall so the revs really drop quite a lot during the change. The manual ratios are much nicer and makes the car feel a lot quicker.
If you're interested, here's a comparison between gear ratios... manual vs automatic.
(The higher the number, the higher the gear ratio (shorter the gear)
..... M..........A
1) 3.214 - 2.785
2) 1.925 - 1.545
3) 1.302 - 1.000
4) 1.000 - 0.694
5) 0.752
First gear on the auto is about half way between 1st and 2nd on the manual box.
Second gear is about half way between 2nd and 3rd on the manual box.
Third gear is equal to 4th gear on the manual box.
Fourth gear is actually a lower ratio than 5th on the manual box - for good highway economy.
Less gears means a larger jump between ratios.. hope this all makes sense ;)
Edited by R34mac
    • I clean my wheels every time I was the car, I also clean the barrels, the only product I use on the wheels is truck wash, followed by wash and wax, cleaning the barrels is easy with one of these microfibre thingies on a stick from Sabco, there also great for getting in between the front guards and body, and tight spots in the engine bay ย
    • An updated post here. Sounds to me like there's definitely a bit of sketchiness here.ย  Old mate with 10 rusting Torana's in the front yard might be more who they're focussed on. (For right or wrong).
    • Is this not just about people wrecking, and storing, multiple cars in their front yard? I now a tow truck driver that was contracted by the council to clean up housing commission front and rear yards in houses and unit car parks I'm all for working on, and doing maintenance on your car in your garage or driveway, but some people definitely take the pissย  There's one house locally to me that I walk past regularly where the front yard and driveway looks like a wreckers, multiple cars in various stages of being stripped, and the yard looks like all of fluids are basically dumped on the ground I may be wrong, but it seems that the initial reports, which I've seen nothing actually official about yet, may be getting taken out of context, like alot of the latest "the sky is falling" stuff found on the youtubes for clicks
    • have they? Link appreciated. I live in Casey. I can see both sides of the argument in this case. There's a lot of sketchy stuff going on. There needs to be a clear definition of what this is supposed to be IMO. I wager the intent was to be a broad sweeping brush against people who have 4 cars up on blocks on their front lawn, not someone who services their own car behind their own gate on a weekend bothering probably nobody. But it'd be hard to legislate the difference there.
    • Oh, the wheels were already off. I wouldn't normally take them off to clean them although it does make it easier with the ceramic, so I might take them off when reapplying. I don't drive much but now with the ceramic coat, when I do drive and they get dirty I can get most off with the pressure washer. I'll be switching to dirtier pads soon which was the motivation for the ceramic as I usually just clean them and sometimes use Autoglym wheel protector. Nah, f**k the barrels! Haha, I'll give them a quick scrub when they're off the car and a pressure wash, but even I draw the line with the barrels. Yes, dark coloured wheels allow you to get away with a lot! ย
ร—
ร—
