R32/r33 3' High Flow Cat, Genuine R33 Rear Strut Brace, R33 S2 Rear Seats, R33 Carbon Fibre Rear Bumper Heatshield [syd]
I have a few more things for sale, located in North Sydney
R33 genuine rear strut brace- $90
Genuine rear brace, a direct bolt on for R33 coupes
R32/33 Hiflow 3' Cat Converter- $100
Full stainless steel, bolt on for all R32 R33 and R34 GTR, and in good condition.
R33 Carbon Fibre Rear Bumper Exhaust Heatshield- $75
R33 GTST rear seats in good condition- $50
pickup only
PM me if interested
Edited by chiksluvit
I'm assumine the the carbon fibre bumper exhaust headshield wouldn't fit an R34. Would love to know where you got it from though.
cat sold
what's left for sale:
pickup only
Rear strut brace sold
adding front King Springs lows for R32 KDFL-101-SP - $60
and Apexi power intake pod filter in good condition, bolts on the RB25/20 AFM -$40
Not sure if the R33 GTR rear bumper's the same as the GTSt, it looks the same to me so i guess it should be ok.
One thing to note is that I've trial fitted it once, and I couldn't get it to fit properly because of the exhaust, I have apexi N1, and the exhaust tip didn't have much clearance from the rear bumper, plus it angles up, so it touches and I couldn't get it on properly, so you might want to double check on that too.
cheers
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
