ok stripping my cefiro.
if someone wants the shell they can have it for $200, its got heaps of bog in the rear quarters and looks pretty shit. rails are straight front end is straight. will come as a bare shell though, no hanging panels, no wiring, no tank no lights, except tails which you can have more than happy to help lift onto a trailer..
so that leaves :
doors 4x fronts 4x rears $40 each
front guards 2x left 2x right $30 each
bonnet good conditon just a bit of paint chipped off $80
boot good condition $60
6 bolt VLSD diff $180
front windscreen has a large crack in it.
rear screen is good, send me a PM if your after it.
GKtech front pipe $50, used for approx 2 weeks, but kept hitting the floor thanks to the catback sitting to high.
ive got heaps of random parts so if your after something particular send me a PM or SMS on 0450472446
i want this shit gone ASAP so any REASONABLE offer wont be refused!!
located in the parramatta area in SYDNEY for those who missed it.
Edited by esky_mad
https://www.sau.com.au/forums/topic/312613-stripping-cefiro/
so that leaves :
I need a LH rear quarter window Urgently. Are you able to help?
have front and rear bars, willing to post guards at your expense. ill have to get a window guy out to remove the rear quarter window, ive tryed taking them out before and just end up smashing them. send me a PM.
Front bar has been chopped up and had a lip screwed into it. was meant for a track car so its way out of place if you want it for a street car.
Yes ive got the drivers side rear door. the regulator assembly needs to be replaced i believe as when i pulled it off my old cefiro the window dropped.
Yes ive got a dash but its seen better days, no vents, the foam is lifting above the cluster section....
wat do u mean the regulator assembly needs to b replaced?
  • 1 month later...
Hey mate, i might be too late. but i'm after all the chrome strips from around the front windows doors and rear window? i got my car resprayed and the painter lost them all.
could you PM me if you could? i dont get on here often.
thanks
  • 1 month later...
    • Holy smokes brother. If you get there before me, let me know if that was manageable with a hone. I still haven't done anything with mine and probably won't until I get the car MOT'd later this year so that I have another 2 years to do what ever needs to be done. I am at 86.5 now so at least I have the 0.5mm to go up from where I am, but that means new pistons at the very least. Honestly, might consider a stroker at that point.  Cheers
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
