  • Replies 51
yeah the 2nd type grows in the "backward".
Anyhoo
I have a set of 2nd hand dunlop formula Rs yet to see how they go but bang for buck a bit over 200 bucks for 6 slicks is a bargain imo.
I just hope it doesnt rain lol
Anyhoo
AhhhhHUH! Same guy, nice catch :(
If anyone is still running 235/45/17's the re55s can be had for $350 a tyre
at present. Not sure if its all 3 compounds but i know for sure they
have sr2's [hard] for that price, which is the pick for weekend warriors anyway!
Good buying i say, there is a group buy on Evolutionoz, having said that
a few of the boys have been grabbing them for that figure from other
suppliers also.
Cheers..
Im just going by what the distributor nsw told me, they had to run 42 psi!
bit late....but this is spot on for Kumho v70A
We used to run these as control tyres and they perform better at road tyre like pressure....we used to run between 42 and 44 hot pressure. In fact performance did not drop of hugely right up to 48-50psi. Very unusual but I can't argue with the lap times.
Well I've got a supersprint this weekend at Wakefield Park and I will try running a bit more pressure in them to see how it goes.
Previously I've only run a maximum of 35 psi hot in the V70A's and the tyre wear was nice and even. I don't have a pyrometer so can't comment on how hot the tyre was getting in places.
If it means I'll gain a bit in lap times Duncan, it's worth a try. :happy:
maybe too late for this weekend.
but there are the 3rd best tyres I have run behind dz03g and re55s, and they are 30-50% cheaper. so a clear winner on cost/performance. If you have to win (ie cost is not a factor), the other 2 are the only option.
Like I said I ran 42-44 for best results on the gtr....but heavier cars like commonwhore ran even higher with good results. of course we are way outside sensible/manufacturer recommendations....just saying what actually works with these tyres.
what happened with these tyres in the past few years by way of history.
around 5+ years ago the v700 were the control tyre for IPRA. those guys get every last 10th out of their cars due to fairly restrictive rules and they found these tyres were actually pretty good. But especially so when buffed (ie some of the "new" tread depth removed). So everyone started peeling 70% of the tyre off, got good performance, but they were expensive to run becuase after the buffing they would only last 1 or at the most 2 meets before being below the tread depth indicators. they still worked fine at that level, almost like slicks, but were not legal because there was not enough tread left.
in the years since, for whatever reason, they were not used much or well regarded. I think this was a mistake, the v700/v70A are a good tyre. Some people like Ben, and for that matter Tony Sullens used them for good effect at events like targa (especially the soft compound).
2 years ago kumho V70A won the production car control tyre contract in NSW from yokohama. That is where I first met them and used 4 sets over 6 rounds trying different pressures etc. There were a further 30 cars running them including the commodores like I said. We found by accident and rumour that they worked best hot (ie people accidently letting them get too high, finding good results then checking pressure to their surprise). Mine definately worked better at that pressure but some guys literally run them at 50+psi getting the best results. Make no mistake these guys are dead serious about lap times because the front running cars are very similar, they would not run these pressure unless they gave results. John from fsport was obviously all over the pressures and results people were getting - no wonder he recommends high pressures too
However, in the low profile tyres (35 and under, like 265.35.18) they started to fail at these pressures. the distributor rightly pointed to over inflation but in the end, due to perceived ureliability they were ditched as the control tyre for safety reason. we now run an open tyre list and the same cars are running 1 or even 2 seconds quicker on the same tracks using dz03G or re55.
no disrespect to ben's experience (hell he can farm potatoes like no-one I know), but targa experience and track testing/development are totally different. there is absolutely no doubt these tyres work better at much higher pressures than others. FWIW I run the dunlops at 32-34psi so I am not some crazy high pressure fetishist.
I've never used AD08 but I have done some track work on high end street tyres. They generally work best with high pressures too (and low aspect ratios) to make up for weaker sidewalls. If I don't have a starting point I use the following guide:
Street Tyres: 38-42
Semi Slicks: 30-34
Slicks: 28-32
Of course lots of tyres are different, and the heavier the car, the more pressure is needed. But it is a good starting point.
Duncan what works with the r35 dunlops? being run flats I guess the rules are different again?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their reliability is proven, performance can be predictable, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
    • Wasn't there a thread on this very subject just a few weeks ago?
    • Hi all! Looking to relocate the battery to the trunk of an R34 GTT. I want to do it using as many stock GTR components as I can (including the harness protectors from the 34 GTR that run underneath along the chassis to the engine bay). So far I’ve purchased the battery tray from a 33 GTR, as the captive weld nuts are already there just asking to be used. There is also the slight issue of now having to relocate the ABS/TC/Fuel Pump Control ECU, which in GTT’s sits right above where the battery will then sit on the tray. Has anyone already achieved this, and if you have any pics that you wouldn’t mind sharing? It would be great to see how others have done it and where you put them, as there are countless holes in the parcel shelf panel to potentially use. Just trying to get some ideas bounced around, and to help uncover any potential problems I may encounter by  my choice of location. TIA for any help!
