sketchr32 Posted March 20, 2010 Share Posted March 20, 2010 hi everyone. im hoping someone could give me a hand please. ive pulled a homemade boost controller out of my series 2 stagea( on there when i got it) and now i want to return the boost lines back to thier correct homes. can anyone help. theres the solanoid with the top and bottom connection spots. theres the wastegate conection, the conection on the compressor housing on the turbo and then i found one sneaky one cable tied shut on the pipe that runs from near the pod filter back to the bov. can someone please lend me a hand. or a pic of thier engine bay with the factory setup i was told by the people that did my 100,000km service that it was installed wrong so jsut want it out Link to comment https://www.sau.com.au/forums/topic/312625-hheeelllpp/ Share on other sites More sharing options...
pyro-ns Posted March 20, 2010 Share Posted March 20, 2010 hi everyone. im hoping someone could give me a hand please. ive pulled a homemade boost controller out of my series 2 stagea( on there when i got it) and now i want to return the boost lines back to thier correct homes. can anyone help. theres the solanoid with the top and bottom connection spots. theres the wastegate conection, the conection on the compressor housing on the turbo and then i found one sneaky one cable tied shut on the pipe that runs from near the pod filter back to the bov. can someone please lend me a hand. or a pic of thier engine bay with the factory setup i was told by the people that did my 100,000km service that it was installed wrong so jsut want it out doing this from memory, but here goes. top pipe on the solenoid is pressure feed (it shouldn't matter, because i don't think it's a 1 way mechanism, but from memory, that's how it is). run a vac line from the intercooler piping, to this. bottom pipe on the solenoid, is connected to the t piece. the hose with the restrictor(s) in it, goes from the t piece to the blow off valve return pipe (it's under another pipe, have a look around for a nipple). the last hose, goes from the t piece to the wastegate. just in case i'm wrong, be gentle on the car when you put everything like this. if your car really surges, something isn't wrong. your solenoid might not be getting power, in which case, your wastegate isn't getting pressure and your car is free-boosting. this is bad for your car and your turbo. if you have a boost gauge (all turbocharged cars should), you should be running no more than 7 psi in standard form. the series 2 stageas run a dual stage boost control, around 5psi up to about 4500 and then 7 psi from there on. it is not uncommon for the stock solenoid to be grounded (by a previous owner), however, which will give you 7 psi all the time. i don't have a pic i'm sorry. if you have a search for the 10 minute boost mod, there should be some pictures somewhere Link to comment https://www.sau.com.au/forums/topic/312625-hheeelllpp/#findComment-5142244 Share on other sites More sharing options...
webng Posted March 20, 2010 Share Posted March 20, 2010 Got a pic for you but for some strange reason I can't i can't upload the pic. PM me your email. Link to comment https://www.sau.com.au/forums/topic/312625-hheeelllpp/#findComment-5142329 Share on other sites More sharing options...
southern_tango Posted March 20, 2010 Share Posted March 20, 2010 (edited) Here,you have some pics,note that the metal connector acts as a restrictor if you need more details just let me know... Edited March 20, 2010 by southern_tango Link to comment https://www.sau.com.au/forums/topic/312625-hheeelllpp/#findComment-5142377 Share on other sites More sharing options...
KiwiRS4T Posted March 20, 2010 Share Posted March 20, 2010 Nick's description is correct. While you're at it you may as well bypass the solenoid and get 10psi but you will need to find the restrictor in one of the lines and make sure it is in the bleed line (or else make one up from a weldind tip or by soldering up the bleed side of the T and drilling a hole in it. Pictures and instructions in post # 40 http://www.skylinesaustralia.com/forums/Ja....html&st=20 Link to comment https://www.sau.com.au/forums/topic/312625-hheeelllpp/#findComment-5142380 Share on other sites More sharing options...
southern_tango Posted March 21, 2010 Share Posted March 21, 2010 Forgot to add that in the first pic.on the top right corner the connector covered in electrical tape is that I grounded the boost solenoid to run 7 psi.all the time... Link to comment https://www.sau.com.au/forums/topic/312625-hheeelllpp/#findComment-5142442 Share on other sites More sharing options...
