  • Replies 48
this is my new fule set up in my r32 gtr
consists of a think a Holley lift pump drawing from a custom 43lt Alie tank filled with fuel foam,
running to a fuel regulator then to the swirl tank then to a bosh 040 external pump and then through a cleanable fuel filter then up to the front,
the in the engine bay to a turbo smart reg and then to the rail
Here is my setup I have been making, not quite up to the flow you guys are probably after for E85, but should be good enough to give me a simple, light, cheap and reliable supply for my track 180...on PULP.
http://www.skylinesaustralia.com/forums/Pu...-C-t316767.html
It will be interesting to see how you go Scott. From what I'm told, and it makes sense to me, is that the standard fuel tank is a benefit for our cars in terms of weight placement (lower CoG), weight transfer on power down, and airflow under the car (not an issue with a flat floor if that's what you're planning). It was for these reasons that I decided to stick with the standard tank and go this setup:
Unknown in tank fuel pump
Bosch 044 external fuel pump
Autobahn888 Surge tank
Custom enclosure
Sard Fuel Pressure Regulator AN#6 fittings
Custom CPC Fuel Rail
Sard 800cc Injectors
2 x Fuel filters
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
