Hey SAU,
Just came across a problem few hours ago. Everytime i reach high rpms my car would start misfiring. When driving the car normally it is totally fine but as soon as i go to give it a bit of a squirt then it will start misfiring between the range of 6-7000rpm.
This video i found on Youtube is exactly what is happening
https://www.sau.com.au/forums/topic/312645-rb20det-misfire-high-revs/
Hey Jesse, cheers for the reply.
What is the chances it could be the spark plugs if it was changed 3 months ago by my mechanic which he would have gapped properly as he got it tune by another tuner on his dyno. Andy from Autosolutions done the work. So i will check to see if it is coilpacks.
Thanks
Just took it for a drive and it doesnt do it anymore I didnt even check or touch the engine bay. Could it be that water didnt dry up properly even though i have the valley cover off? I had the car pressure cleaned hours before it started to problem..
Could be boost leak? I had the same issue and was fine driving normal. Under boost it would misfire at high revs. I changed plugs, coils, filters, and ended up finding a hole in my cooler piping about the size of a tic tac. Fixed this and fixed the problem.
DO NOT put any water in the coilpack valley. Most likely this was the problem.
If it comes back, note what temp. the car is at and how long it has been driving. If it's heat related it could be coilpacks on their way out or the coil harness deteriorating. If it does randomly (not dependant on temp.) then I would be looking for a loose connection (earth wire at the back of the coil harness maybe or coil plugs falling apart).
This is what I mean by random.. the plugs on my coil harness were falling apart from the inside and intermittently breaking contact.
Edited by bubba
  • 2 months later...
I've changed my coil packs with super spark ones i've changed my spark plugs with brand new iridium/platinum ones . . and the problems still there. . no water in my fuel . . i even put a sard fuel pressure regulator on it and changed the boost up and down to see if it makes a difference but nothing changed . . so ther was a leak from your intercooler?? maybe thats my issue . . ive tried so much to get rid of the missfiring its so annoying :banana:
  • 2 years later...
More boost that stock due to large exhaust + intake mods = rich and retard, this plus bad plugs and or bad coils = misfire.
The richer the mixture the harder it is to ignite, the weaker the spark the more likely the flame will be blown out, so some combination of bad tune either from a stock ecu + more boost, or a retuned ECU too rich plus the stock ignition equipment shitting itself will result in a misfire, fix these things one by one and your problem will go away.
Cold weather will mean more air which means even richer mixture, but it means less heat in the coil packs so it may make the problem worse or better.
Edited by Rolls
    • They're so beautiful 😍
    • Early last week, I became concerned that the car was feeling....slow. Most of my driving is commuting to/from work and there are few opportunities to get up it and convincingly make boost/power. It drives in vacuum almost all the time. But when you do occasionally get an opportunity, and.... it takes a little longer to start making power, and then there's not as much as you'd expect, and then you run out of road anyway and have to bottle out - it can be hard to be convinced that there's something wrong. But by the end of the week I was pretty convinced. Made an effort to get a decent test run. Took bloody forever to come up on boost and when it did it would only make about 50 kPa of pressure. There was no black smoke, no noise of a boost or exhaust leak, no evidence anywhere of an intercooler hose clamp being sloppy enough to let air escape. So.... not that sort of problem. Brainstorming led to thinking that the boost controller's solenoid might have failed in some way. No active boost control would just give wastegate pressure, which I was more or less getting, and the laggy behaviour could just be "normal" shitty boost response from an uncontrolled highflow. But a little extra 3rd party brainstorming led to the thought that the actuator circlip might have jumped off leaving me with a bluetooth wastegate. So, on Friday, off comes the stock heatshield (which is an annoying enough job on its own) to reveal - yup. WG is wide open. And.... it won't come back. It is jammed in the dump. Put the rod back on with a new circlip and tried driving it to get it hot in the hope that the capture was from thermal effects having been blown into the dump when hot and since cooled. Nope. Won't move, even with screwdriver mediated force when hot. Ran out of time to play. Came back to it yesterday. Unbolted the dump. Was lying under it with the dump jammed up against my guts undoing the bottom 2 bolts. Got them most of the way out and gave the dump a serious heave. It didn't noticeably move, but there was a satisfying "plink" noise from up to. Shuffle out and sure enough, gate is now closed. Nevermind that there was still the better part of an hour after that required to put it all back together. f**ken cars.
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
