Hey SAU,
Just came across a problem few hours ago. Everytime i reach high rpms my car would start misfiring. When driving the car normally it is totally fine but as soon as i go to give it a bit of a squirt then it will start misfiring between the range of 6-7000rpm.
This video i found on Youtube is exactly what is happening
https://www.sau.com.au/forums/topic/312645-rb20det-misfire-high-revs/
Hey Jesse, cheers for the reply.
What is the chances it could be the spark plugs if it was changed 3 months ago by my mechanic which he would have gapped properly as he got it tune by another tuner on his dyno. Andy from Autosolutions done the work. So i will check to see if it is coilpacks.
Thanks
Just took it for a drive and it doesnt do it anymore I didnt even check or touch the engine bay. Could it be that water didnt dry up properly even though i have the valley cover off? I had the car pressure cleaned hours before it started to problem..
Could be boost leak? I had the same issue and was fine driving normal. Under boost it would misfire at high revs. I changed plugs, coils, filters, and ended up finding a hole in my cooler piping about the size of a tic tac. Fixed this and fixed the problem.
DO NOT put any water in the coilpack valley. Most likely this was the problem.
If it comes back, note what temp. the car is at and how long it has been driving. If it's heat related it could be coilpacks on their way out or the coil harness deteriorating. If it does randomly (not dependant on temp.) then I would be looking for a loose connection (earth wire at the back of the coil harness maybe or coil plugs falling apart).
This is what I mean by random.. the plugs on my coil harness were falling apart from the inside and intermittently breaking contact.
Edited by bubba
  • 2 months later...
I've changed my coil packs with super spark ones i've changed my spark plugs with brand new iridium/platinum ones . . and the problems still there. . no water in my fuel . . i even put a sard fuel pressure regulator on it and changed the boost up and down to see if it makes a difference but nothing changed . . so ther was a leak from your intercooler?? maybe thats my issue . . ive tried so much to get rid of the missfiring its so annoying :banana:
  • 2 years later...
More boost that stock due to large exhaust + intake mods = rich and retard, this plus bad plugs and or bad coils = misfire.
The richer the mixture the harder it is to ignite, the weaker the spark the more likely the flame will be blown out, so some combination of bad tune either from a stock ecu + more boost, or a retuned ECU too rich plus the stock ignition equipment shitting itself will result in a misfire, fix these things one by one and your problem will go away.
Cold weather will mean more air which means even richer mixture, but it means less heat in the coil packs so it may make the problem worse or better.
Edited by Rolls
