Got all these parts leftover from the Skylines which i have wrecked. Parts will be available untill 26th of March then again from the 14th April as im going O/S.
R33 GTST:
Front Subframe - $40
Rear Bar Reo - $30
Space Saver Wheel - $20
S2 Door trims, have factory holes for tweeters - $15 Each
Radiator hoses - $10 each
Glovebox - $20
Auto Brake Pedal - $15
Accelerator Pedal - $15
Interior Carpet - $30
Windscreen wiper stalk X 2 - $20 each
Boot trim, no carpet, few cracks which are unnoticable once fitted - $30
Turbo heatshield X 2 - $15 each
Windscreen washer bottle - $15
Seatbelt set - $40
Undertray stoneguard - $30
Turbo intake pipe - $15
ABS unit 1995 - $40
ABS unit 1998 - $50
S2 Passenger seat, small stain would be removable- $50
Automatic cooler - $20
Automatic shifter surround - $30
Aircon Condensor - $40
Centre console with Auto swich - $20
S2 Dash Surround, VGC - $30
Jack and tool kit - $30
SRS passenger Airbag - $50
Airbag module - $20
LHS front suspension components, hub-uprights etc, bent lca - $50
RHS front suspension components, hub-uprights-lca etc - $70
R32 GTST:
Front Strut-brace - $20
RHS front hub-lca-uprights - $70
Sony Xplode headunit - $25
Please contact via PM. Pick-up is highly prefered but will post items $40 or more of value. Pick-up from Emerald after 6pm or at Boxhill on Mon/Thur/Fri. Cheers
https://www.sau.com.au/forums/topic/312693-leftover-r33-r32-parts-from-wrecks/
Can you email photo's to [email protected] for door trims?
Didn't know they had factory tweeter holes??
Also what condition are they in? Any scuffs/marks?
Might be keen for the S2 dash surround and possibly the tool kit too. I already have a jack though.
Oh, damn I wish you had a manual shifter surround too! Oh well, the S2 dash surround will keep me happy for now.
PM pics of both please?
Cheers, Jad.
Cheers, Jad.
Sorry mate, bet you to it :blush:
R.C. E-mail sent.
theforce. Replied
JadGTST33. If sale falls through will let you know.
Borci88. Sorry been sold.
slidnreds13. Got a guy coming to pick it up tonight, if it falls through will let you know.
Also have good condition roof lining - $25
Hi I need the front subframe, also looking for front bumper support, front left fender, left headlight, left bumper turnsignal and hood? do you happen to have any of these parts? if so pm me with prices please and pics if possible also are you willing to ship to the US? let me know I need these parts thanks.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
