have you tuned the ecu to suit the injectors eg power fc have you adjusted the duty on the hand controler-
Yes, I have adjusted the injector settings ,but the duty not yet. How do i go by adjusting the duty on the hand controller.
Thanks.
Hey man
If you set the injectors up in the hand controller you would have set the scaling for the injectors (as a Percentage) and then you would have adjusted the lag/latency of the injectors (+ or - a small number like 0.12 or something). That should be enough to set your new injectors up for now.
When it comes to only being able to get shit fuel, i had a similar problem. If it is only a small small town, the fuel sells slowly and they only had 91, chances are that the fuel is shit. If you have the chance to travel a little further and grab some fresh 98 I would highly recommend it. I bought "premium" from the local servo in my little town and its was absolute shit.
When you are turning it over, are you getting ANY ignition at all? Does it even try and fire in the slightest or will it just turn and turn and turn?
Thanks.
EDIT: Have you set the base fuel pressure? Is it possible to just use the stock FPR for now while you try and get it running?
Edited by Lukas 33
Hey man
The injector setting are place in already 65 % and 0.20 ms thats the setting that i input. As for the fuel is real hard to get a higher octane, i would have to mix to get that rate.
Yes, i have ignition (checked by inserting the plug into the coil and place it near a ground). When I tried to fire her up, you would hear it firing up ,but after that she just turn n turn n turn. I also tried with WOT while cranking her up.
Thanks
Oh ok so you have spark. Sorry man I meant ignition as the fuel actually igniting. So it did that a few times and now you just have nothing? If you still have spark I really can't suggest anything but the fuel. How long ago did you get this 91 octane fuel? Also what is your fuel pressure?
Thanks
If you can only run 91 fuel, you will need to take some timing out of the maps.
Also, what is the setting for timing during start? RBs like a lot, like 40-45 deg.
When trying to start after flooding, you need to just keep cranking - could take nearly a minute to clear the excess fuel. The engine won't start like normal.
I will try to change the fuel that i have in the tank , i belive it had the for month or so. The fuel pressure that i set on my sard reg. is around 50psi, but i notice once i stop cranking the pressure drops
slowly,would that cause less fuel or the duty cycle.
if the pressure drops..there is a leak..in your fuel supply... could be the cause of piston problems
I have check all fuel lines,fittings and on sign of leaks...could the fuel pressure reg. be cause of leaks.
I will be on the look for a new reg.
Thanks
    • Next pic will probably bring back Charlie's PTSD So yes, pump is back out. I hooked the fuel return up to a hose into a container to flush out the first litre or 2, jumped the Fuel Pump relay and.......nothing.... Turns out the pump I had pulled out, checked, cleaned everything....was dead.  I hadn't actually hooked 12v to it to check it worked before I put it back in. Anyway...Neil had kept the old pump which still worked, so I just swapped it back in. All good, flushed the lines out, ready to start
    • OK....so something that works like it said on the tin! Fitting the pressure feed into the car was an absolute PITA because the oil filter is in the standard location and then there is a fitting to run to the oil cooler. On the other side between the filter and the steering box is the standard oil pressure sender (not working for some reason, something to check) and 2 tapped 1/8 BSP threads for the oil temp and pressure gauges. Unfortunately it is really tight in there and it took a hours of stuffing around to get a t fitting to connect the priming pump and retain the gauge sender.  Also, the Aeroflow sump has some massive drain plug (needs a 32mm spanner) so I couldn't use the regular fitting there either. In any case....once it was all hooked up, like magic priming.mp4 15 sec, 3 bar of oil pressure. Left it running a couple of minutes to push through everything, looked good
    • Yeah the latest style kit has been trouble free, I've done a fair few klm on it including pushing a bit on low fuel and it hasn't been surging (that's not an endorsement for race use, I haven't tried that low, or that hard cornering!). For street use it has been a good thing, handles the high current OK, only real issue is it is not cheap
    • So, how do you feel about the Frenchys surge tank setup @Duncan? Have you had a chance to try it out more? The sketchy wiring in my fuel pump setup has decided to melt and die and I'm looking for a solid replacement now. My fuel hat is toast so the Frenchys kits providing it all look promising.
    • Yeh... literally every time i jump on a forum, see an instagram post or see an engine bay at a car show, i get an idea and add it to my 'to do' list. So what started off as, hey can u just make a couple of intake hard pipes because my dumbass bought the wrong apexi kit, blew out into a 2 week job including braided brake lines & custom bash kit for the front lip haha.  Getting Luke from A4E engineering to make a full custom exhaust with a controllable aes dump valve so i can actually switch between quiet and loud, because right now its just loud all day every day. Then after that go and get the tune redone flex e85 & 98 as i get bugger all milage from e85, makes going for longer drivers difficult
