hay guys, iv got a r33 s2 skyline, its got a mongoose m80 2button alarm and immobiliser. i was driving my car back from geting new tyres put on yesterday, and we herd a soft siren, i thought it was a shop or car, exept it didnt go away. i opend my bonnet and it was coming from the alarm box. it stoped wen i switched it to silent. i took it home and turned it back on. it did it again but once it armed it stoped. 2day i drove to 2.5hours 2day with no problem. went to the wash and as i pulled in i herd it again. so at the moment its on silent. if somone could help me please, i have no idea. maby backup battery?
https://www.sau.com.au/forums/topic/312731-alarm-sirens-while-driving/
OK! First things first. Who fitted it? If it was fitted by a qualified installer, go back to the shop it was fitted and get them to look at it. If you did it yourself, I think you may have made an error in your connections. I installed an alarm in the in-laws car and they had the same problem. After some investigation and research, Google is your friend, I found that the immobiliser relay was not connected properly. This may be your problem.
But first, I would suggest you take it back to the shop where it was fitted, if that is the case.
Good luck!
If it is as simple as the siren being f&*ked, you can simply head off to jaycar and buy one of their universal sirens. Connect it up via the siren signal wire and bob's your uncle.
If you don't know how/what you're doing, it may be a better idea to head off to a sparky and sort it that way.
    • Hello, I'm trying to make this thread basically the thread with all the answers to common questions regarding specifically the RB20 DE NEO + T engine, that comes in the R34. Answers will and only should be provided by those who have done this conversion or actually have some relevant real life experience please. Please feel free to ask questions in the comments if you have any so other members can answer. I feel like this thread is really needed, especially with more Americans buying (unknowingly going to regret it too) rb20 neo r34s. My first question being - What do you guys use for tuning? I have purchased a haltech elite 2500 Plug and play kit for the rb25det NEO because the ecu plug is the same, but I am unsure if any of the pins would need to be repined to match. Second question that I see asked very often - After this conversion, did you install the boost solenoid/ actuator? I see many people doing a + T setup on their rb20 NEOs while running stock RB25DET NEO ECUs with no tune. I am wondering how they are going about doing that and consistently abusing the car because many of these people have had these untuned setups running for a very long time. That was my original plan, but my engine cuts out at 5 psi of boost using the stock ecu with no tune and no boost solenoid/actuator.
    • interesting. ive read and heard otherwise over the past year. ive been doing this +t conversion on a rb20 neo using all oem rb25det neo parts including the ECU, and im having engine cut out issues when I hit around 5 psi of boost. Everywhere/everyone ive asked has told me its because I never wired in a boost solenoid/actuator to the ecu, so the ecu isn't getting the right signal once it hits 5 psi of boost, causing the engine to get shut off.
    • Mate, I take this thread in random directions on occasion myself, so no foul I'm a old fan of MCM anyway, I like their banter, and enjoy most of the stuff they do
    • Something strange is happening. I didn't touch the car since we last spoke on the forums. Yesterday was the first day of good weather, so i took it out for about 2 hours. It started up on first crank every time about 5 times total. I literally didn't do anything to do the car.
    • I purchased this one. Very well priced and works great. I was rough with it to see if it will last and had no issues.  Teslong Two-Way Articulating Borescope with Light, Industrial Endoscope Inspection Camera with Articulated Probe, Flexible Mechanic Fiber Optic Snake Scope Cam for Wall Automotive Engine Inspect-5FT : Amazon.ca: Industrial & Scientific
