Item Summary: R32 Gtr, Fored, Single Turbo, $24,000 Quick sale!
Item: 1989 R32 GTR
Item Condition: small paint chip above front right hand wheel arch from -offset rims, other then that the paint is great, small rubber gromets in boot where spoiler was removed.
Price and Payment Conditions: $24,000 with road worthy
Please note I'm not after any swaps thanks. Just needs to sell.
Info:
Engine:
CP Forged Pistons 86.5mm and rings
HKS 264' in\ex cams
Adjustable cam gears
High flowed ported and polished head
Stainless steel multilayered head gasket
R33 reman crank (larger oil galleries)
Eagle Rods
ARP main studs
ARP enlarged head studs
N1 oil pump
N1 water pump
Tomei oil restrictor
Block crack tested, honed and decked
ACL race bearings
New Gates Timing belt and genuine idler and tensioner
Gates radiator hoses
APEXI Power FC w/ hand controller
Delphi 1000cc injectors/ new o-rings
Super Direct ignition coils(red)
New 90A alternator
Braided enlarged fuel lines
NISMO Fuel pump
NISMO fuel reg
Brand new genuine CAS ($1200)
Custom alloy catch can with twin breathers- -18 Earls fittings and braided line
Twin RB25 AFM with new mushroom pods
Heater hoses, fuel filter, oil filter and oil have just been changed.
Turbo and pipes
Holset Hx35x turbo with antisurge ports (done 10 000km's)
HKS 55mm Wastegate (modified to be adjustable)
HKS power intake pipe
HKS low rise manifold
HKS pipework and intercooler
3 inch fujitsubo exhaust system
Brakes/Suspension/Driveline
HKS Hypermax 2 coilovers and springs(excel condition)
CUSCO rear stabiliser
Project D front upper adjustable camber arms
25mm Aluminium spaces and new bushes on front
5mm spacers on rear
R34 Brembo Callipers with recent overhaul
New 330mm Rotors and pads front
R34 master cyl with CUSCO brake stopper
Rear brakes standard but slotted
OS Giken Triple plate clutch and fly wheel, rebuilt by NPC as a twin plate to hold 600Hp atw. (rebuilt 10 000km's ago at a cost of $1100)
Brand new genuine Nissan Clutch slave cylinder
New nissan spigot bush
New nissan rear main oil seal
New nissan throwout bearing
NISMO Strong Release Fork Pivot (30% stronger)
Redline Lightweight shockproof g/box oil
Kazz 2way Diff (New 'solid' type) done 5000km's
Kazz diff oil
new gaskets, pinion seal, axle seals, and bearings
new CV boots
Interior
Saftey 21 5pt Roll cage(Engineered) (Car therefore registered as 2 seater but this can be changed with removal of cage)
Recaro Drivers Seat w/ bride rail (Engineered)
OPM 90mm dish suede steering wheel with momo button and boss kit
Mines 320km speedo
oil temp, water temp, oil pressure, air/fuel ratio gauge on passanger side dash
autometer carbon series boost gauge in drivers side air duct
Pioneer head unit
Pioneer 6" speakers in rear, standard in front
Old school turbo timer, 30sec increments
Drift button on handbrake
Greddy gear know and leather boot
4wd/2wd switch on dash
Exterior
Ganador mirrors (electric)
N1 headlights
N1 Rear pods
Vertex Sideskirts
N1 front air ducts
Jap Spec clear indicators
8500K Hid Kit
White led number plate bulbs
Wheels:
Rear- 235/45/R17 Work Manaray's. 9.5" wide with +10 offset
Front- 235/45/R17 Sparco Racing Rims. 8.5" wide with +30 offset (25mm spacers take it back to +5 offset)
Gt Radial Tyres
Extra info
- The car is modplated for the roll cage, 2 seat conversion, brake upgrade, and seats
-Serviced every 3000km's
- 129 xxx on the odometer
-Car has be featured in HPI magazine issues 108.
- Tuned at Godzilla Motorsports on the 25/6/2009 by Mark Jacobsen
- Car is currently making 370hp at all 4's on 16psi
and run a flat 12.00sec 1/4mile at 111mph
motor and turbo are built to handle much more boost then this however at the time 16psi was what i wanted it tuned to to suit my needs of daily driving and even a flat 12sec isnt to shabby for a street car. ;)
with simply a retune you would easily see 400hp+ at all 4's and break into the 11sec bracket
This gtr is truly awesome to drive.
Pictures: Below
Contact Details: PM on here, or ring my mobile 0439666827
https://www.sau.com.au/forums/topic/312738-r32-gtr/
This used to be my old GTR.
Was a fantastic and reliable GTR when I owned it, and has continued to stay just as tidy in Zach's possession. Good job dude. Good luck with the sale.
If you want to go get some decent pics one day, I'd love to do it for free. Give me a text or pm on boost and we can work something out.
https://www.sau.com.au/forums/topic/312738-r32-gtr/#findComment-5145461
Thanks Chris! yeah i was gona get onto you at some stage about getting some decent pics. The ones ive used are a bit blury and don't show how clean and straight the body is. Ill send u a msg sometime and organise it. Zach
https://www.sau.com.au/forums/topic/312738-r32-gtr/#findComment-5145789
  • 2 months later...
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
