so much good infomation comes though this site its hard to keep up.
I personally am interested in the rb25det as i have one. So i want to start a thred were we can create a mod manual that people can add too. I am curently stripping my engine down after a blow turbo has spat its guts though my cooler and into the engine. (dam air filter cam off) so been searching for modes i can do with out going to extreme and high cost.
What i have found: ( most info from SydneyKids posts )
- use oil coolers, mount in a spoiler vet to get better flow.
- 9 to 1 compression or close to
- use the standard nissian head gasket, but 0'ring the block. aparently they seal better than a metal.
- standard injectors are ok , but use a fuel pressure regulator.
-upgrade fuel pump minimum, GTR fuel pump
-Restrict the oil flow to the cylinder head, there are 2 feeds from the block to the head, block off one of them which is the same as an rb26,standard.
-use safe air fuel ratios 12 to 1 as a limit
-Tomei poncams 256 to 260 give good power increase over stock through out rev range. They also dont need adjustment and standard timing gears can remain.
-rb30 bottom end is not good bang for buck when talking street cars
It would be great if people could state their best mods or worst. so we can create a very usefull thread, cost of mods would be great
I hope this gets people started.
https://www.sau.com.au/forums/topic/31275-lets-sum-things-up/
  • 2 months later...
yes i would like to modify my car it is a 85 pulsar hatch with a tip. it currently leaks lots of water from the cooling system and the gearbox is stuffed.
the best mod was when i replaced the standard air filter with another one from marlows.
the worst was when i tried to go 4wd driving at lancelin, hey tim!
Hmm, well to start with, the mods that you do and dont do, will vary greatly depending on the power you are aiming for. You say dont do injectors, but upgrade the cams? Why would you be putting in cams unless you are at the stage where you need to upgrade the injectors? asking for trouble.
Why pull the head off to o-ring the block unless you are once again chasing some decent power? certainly the stock head gasket is fine until well over 250kw. If you are pulling the head off, make sure you change the timing belt at the same time.
It could be argued that an RB30 is an excellent value for money upgrade, once again it depends on how much power you want and where you want your torque. I spent alot of money on cams, custom manifold, head gasket - once you figure in return from selling the stock RB25, a 3L conversion, such as the ones RIPS sell, would have probably made better economical sense, and given me a bottom end power band (which is where street cars spend most of their time) that just cannot be duplicated by an RB25 - just depends on what you are after.
I think if you want to start an 'power upgrade thread' you need to look at things from the beginning, and progress in a logical manner, once you start pulling the head off, it opens a huge can of worms, as then you start thinking about porting, cc combustion chambers, o-ring block and head (as mentioned) etc - talking some serious work here, and it can be very expensive.
A logical sequence of events IMHO would be
Exhaust (cat back or full system, and make sure you do something with the joke of a cat)
FMIC,
Pod - must be with a partition and CAI
Bleed or EBC
Fuel pump
Management (SAFC, ITC, full ECU - once again depending on what you are after)
If you dont have a full exhaust system, now is the time
Exhaust cam gear
Clutch (may have already given up the ghost - if you are chasing over 250rwkw, I would suggest a twin plate+ or otherwise a super single should be fine)
You now have around 200rwkw+ at 12.5psi boost, from here things get a bit tougher and more expensive. You need to have a good mind as to what you want to acheive power wise, and be careful not to over engineer the car
This is just the power side of things, think also about suspension, shocks and springs - or coilovers, castor, camber, diff, wheels, brake pads. You may not be doing all these straight away, but I can recommend you give them alot of thought, as being able to get power down, and handle well makes far more differance to the feel of the car, and the pleasure of driving than just the push in the back when you nail it -IMHO I learnt this the hard way spending thousands on power, only now spending probably around 1-2k on final sus mods like castor and diff, camber and hicas removal - bang for buck with suspension in phenominal.
Going further, if this is what you want, you should have full management, and hopefully some injectors on the way. Then comes the big one, what turbo? the choice in turbo will make or break an upgrade, so before it can be answered at all, you need to consider what sort of power you want, keeping in mind that a strong bottom end and mid range may mean you cant have a fantastic top end, midrange and top end, forget bottom end, etc. The more power you want, the more lag you will have.
Right about now is a good time to consider if you want to go down the RB25 path, or go 3L which will give you tons more torque down low, and is capable of spinning up a much larger turbo, quicker than an RB25.
Not that the car has to be a dog to drive off boost, but it will be very different. You also need to think about pushing the rev limiter right to compensate - really there are just so many variables here, its an entire thread on its own, that could go on for pages by itself.
Actually, having just written all this, I just remembered that www.meggala.com has a build up section that covers alot of this. It would be worth checking his site out.
good luck
EDIT: an oil cooler, a must for the track, otherwise debatable if it is really necessary for a car you just drive on the streets - cant hurt, but its not all that cheap.
I posted this up so long ago and did realy put alot of thought into it, i mean you can just do a search in the area of mods you interested in. But if people would like to ad there formula to make good power then get stuck in. thanks for taking the time steve.
mentoz: hey jame yeah it was fun whiping past some 4wd in a fwd pulsar just didnt think about having to slow down to turn around, (boged, and having every person shake there head as they went past.) :) good old days.
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
