canarygsr Posted March 21, 2010 Share Posted March 21, 2010 hey guys is there a link to somwhere that has pics of the handbrake setup?? i can see people talking about them but cant find the thread for the pics... i think i have been given the wrong handbrake.. damnit!! Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/ Share on other sites More sharing options...
canarygsr Posted March 21, 2010 Author Share Posted March 21, 2010 sorry guys dont know what happend there with it coming up 3 times, also does any1 have a pic of the back of an R34 clutch pedal?? mine fits in fine i just dont like the way it attaches to the firewall, looks loke its ment to have another piece in it to sit against the firewall better, ill take some pics of mine and post them when i get a chance Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5142826 Share on other sites More sharing options...
M I K E Posted March 21, 2010 Share Posted March 21, 2010 this is the best i can do for a c34 handbrake pic for the moment Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5142865 Share on other sites More sharing options...
KiwiRS4T Posted March 21, 2010 Share Posted March 21, 2010 In the morning when its light I will take a photo of mine - the cover is off atm. Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5142876 Share on other sites More sharing options...
GoldZilla Posted March 21, 2010 Share Posted March 21, 2010 The manual conversion thread is HERE, and I myself have posted quite a few photos of the handbrake location in there somewhere... Sorry, can't help with the question on the pedals, though. Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5143100 Share on other sites More sharing options...
darrinspencer Posted March 21, 2010 Share Posted March 21, 2010 Do you know what hand brake you have got The skyline ones are very similar to the stagea one, but the mounting feet are different angles I used a brand new stagea one for ease, was aprrox $170 and was not worn out. To make things easy you need to use the mounting bracket that is normally welded in on the tunnel. The bracket is made of 2 peices spot welded together. Series 2 auto's have one part of this bracket already so you only use one half of the new bracket. Series 1's I believe need to use the whole bracket. Either weld or bolt to the floor. Then the hand bracket will sit at the correct angle and line up with the centre console. Same with the clutch pedal, the stagea and r34 are the same, but the mounting bracket to the fire wall is different. Grab a stagea one and you will be right Have you got a centre console yet? I might be getting a spare one and possibly the pedal brackets etc. Attached is a couple pic's of a full stagea manual conversion. Might help Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5143413 Share on other sites More sharing options...
KiwiRS4T Posted March 22, 2010 Share Posted March 22, 2010 My conversion is from an RB33 GTR so maybe that makes the pedals easier to fit. If you look at the handbrake you will see that it is bolted on to a black plate. The plate looks as though it is rivetted on but is in fact welded to the tunnel. Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5143743 Share on other sites More sharing options...
canarygsr Posted March 22, 2010 Author Share Posted March 22, 2010 i dont know what handbrake they gave me but it was the wrong one, it had R33 in texta on it by mistake, all good now and have the right one, where do i get that bracket from?? do i realy need it?? has any1 else made there own brackets??? or is it a cheap part to get??? all the frontcuts i looked at today had been cut just after the gearstick hole Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144242 Share on other sites More sharing options...
darrinspencer Posted March 22, 2010 Share Posted March 22, 2010 i dont know what handbrake they gave me but it was the wrong one, it had R33 in texta on it by mistake, all good now and have the right one, where do i get that bracket from?? do i realy need it?? has any1 else made there own brackets??? or is it a cheap part to get??? all the frontcuts i looked at today had been cut just after the gearstick hole You can buy all the brackets from nissan. approx $70 for the handbrake one Much easier to use the factory bracket so that you do not rip out of the car over time when pulling the brake on Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144414 Share on other sites More sharing options...
canarygsr Posted March 22, 2010 Author Share Posted March 22, 2010 You can buy all the brackets from nissan. approx $70 for the handbrake oneMuch easier to use the factory bracket so that you do not rip out of the car over time when pulling the brake on ill go into nissan tommorow and see what they can do for me.. that part number on the bracket is that a stagea one or an R34 one?? also is this diagram right?? it just seems strange that there isnt anything siting flat on the fire wall instead of the circular points around the bolts being the only thing in contact with the fire wall, Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144436 Share on other sites More sharing options...
darrinspencer Posted March 22, 2010 Share Posted March 22, 2010 ill go into nissan tommorow and see what they can do for me.. that part number on the bracket is that a stagea one or an R34 one??also is this diagram right?? it just seems strange that there isnt anything siting flat on the fire wall instead of the circular points around the bolts being the only thing in contact with the fire wall, The bracket is out of a series 2 manual stagea, not r34 That is right for the bracket onto the fire wall, that it fits thru the sound proofing.. There is also some other mounting points which fix to the dash cross brace Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144494 Share on other sites More sharing options...
canarygsr Posted March 22, 2010 Author Share Posted March 22, 2010 The bracket is out of a series 2 manual stagea, not r34That is right for the bracket onto the fire wall, that it fits thru the sound proofing.. There is also some other mounting points which fix to the dash cross brace and u got that bracket localy??? Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144523 Share on other sites More sharing options...
darrinspencer Posted March 22, 2010 Share Posted March 22, 2010 and u got that bracket localy??? local nissan, but it had to come from japan Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144644 Share on other sites More sharing options...
canarygsr Posted March 22, 2010 Author Share Posted March 22, 2010 local nissan, but it had to come from japan mmm, i cant wait 3 weeks for that.... i might have to make up a temp one, did you weld yours to the tunnel or are they riveted on like in that other guys pic?? Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144695 Share on other sites More sharing options...
darrinspencer Posted March 22, 2010 Share Posted March 22, 2010 mmm, i cant wait 3 weeks for that.... i might have to make up a temp one, did you weld yours to the tunnel or are they riveted on like in that other guys pic?? Used 4-off 6mm bolts with lock nuts in the tunnel Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5144976 Share on other sites More sharing options...
Oki34 Posted March 23, 2010 Share Posted March 23, 2010 I drilled the spotwelds out of an R33 to remove the handbrake bracket. Worked great along with the handbrake itself and the clutch pedal/master cylinder. Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5146642 Share on other sites More sharing options...
canarygsr Posted March 24, 2010 Author Share Posted March 24, 2010 I drilled the spotwelds out of an R33 to remove the handbrake bracket. Worked great along with the handbrake itself and the clutch pedal/master cylinder. i might see if ican find a 33 at the local pick apart then cause the import ones didnt have what i wanted.. also what clutch is every1 using?? my mates gunna order me an exedy clutch, do i just get one to suit an R34 or does the r34 use a pull type clutch?? im using a 32 gearbox so its a push type... Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5147770 Share on other sites More sharing options...
QWK32 Posted March 24, 2010 Share Posted March 24, 2010 (edited) i might see if ican find a 33 at the local pick apart then cause the import ones didnt have what i wanted.. also what clutch is every1 using?? my mates gunna order me an exedy clutch, do i just get one to suit an R34 or does the r34 use a pull type clutch?? im using a 32 gearbox so its a push type... R34 GTT uses a pull type, unsure of R34 GTR. Most R32 GTR's are the push type but as darrinspencer will confirm, the later model ones are a pull type. Edited March 24, 2010 by QWK32 Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5147936 Share on other sites More sharing options...
darrinspencer Posted March 24, 2010 Share Posted March 24, 2010 R34 GTT uses a pull type, unsure of R34 GTR. Most R32 GTR's are the push type but as darrinspencer will confirm, the later model ones are a pull type. Josh is right All Rb flywheels are the same I use a late model R32 gtr box which is pull type rebuilt by Jim Berry for approx 300rwkw cost around $900. Looking at upgrading when the new engine goes in as it slips already esp being AWD Push type clutches are cheaper Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5148844 Share on other sites More sharing options...
canarygsr Posted March 25, 2010 Author Share Posted March 25, 2010 Josh is rightAll Rb flywheels are the same I use a late model R32 gtr box which is pull type rebuilt by Jim Berry for approx 300rwkw cost around $900. Looking at upgrading when the new engine goes in as it slips already esp being AWD Push type clutches are cheaper All rb flywheels rnt the same, I just compared the one I was given being told it was an r34 flywheel.. To my r32 gtr flywheel I had and they are difrtrnt.. So confused what to do now... Gtr or r34 flywheel... The guy at exedy said gtr push type kit.. Mote feedback from other guys please Link to comment https://www.sau.com.au/forums/topic/312755-c34-manual-conversion-issues/#findComment-5149709 Share on other sites More sharing options...
