hey guys and girls, not in a rush to sell or anything just really testing the waters out,any low ballers/time wasters/shit/tyre kickers will be ignored,
Toyota sprinter 1986 built trueno ae86 Gt Apex model this car is not like most you see with all jdm parts on a aus shell this is a direct import from jap land.
Note: most of the interior, air cond, stereo, rear seats, carpet, sound deading has been removed but most will come with the car, with all the fibre glass stuff this thing is so damn light.
Model: JDM 1986 AE86 GT APEX
KMS: 101,000
Colour: White with black bumpers
Transmission Type: Manual
CAR HAS POWER STEERING
Spec list
Body:
Seam welded front end radiator support
Riverted rear end
Origin Body kit (front bar, side skirts)
Fibre glass rear hatch (very rare item)
Black Fibreglass venter Bonnet with bonnet pins locks.
Lexan rear hatch window
Lexan rear quarter windows
TRD ducktail
Front and Rear widebody guards
JDM side window weather shields in a natural finish
Engine:
20v block with big port head (built by sprinter man)
Alloy rad
oversized water pump pulley
Trd extractors
metal hi flow cat
modded throttle body.
full custom airbox setup
8mm leads
Interior:
Full electronic dash (very rare)
Full original black interior
Nardi deep corn steering wheel with boss kit(not included as it was a present)
Trust Grex white gear knob
BRIDE zeta 2 bucket seat & Rail (driver)
BRIDE brix bucket seat & Rail (passenger)
Full Cusco 6 point bolt in roll cage with black padding
Handbrake drift button
(most interior is stripped out but will come with the car)
Sound deading removed.
Wheels and Tyres:
15 x 8 - 5 SSR MESHIES (front)
15 x 9 - 5 SSR MESHIES (rear)
Front tyres: Yokohama Advan Neova AD07 (dot rated) 60% tread 195/50/15
Rear tyres: Yokohama Advan Neova AD07 (dot rated) 60% tread 195/50/15
Drive-train:
Jap spec T 50 5 speed gearbox (unknown gear set...short)
Heavy Duty clutch
TRD 1.5 Way
Suspension:
Front - G4 front coil over’s with an 8kg spring rate with
camber tops
Rear – TRD green shocks (dampener adjustable) with TRD
Springs 6kg
Front & Rears whiteline sway bars
chasi braces ultra racing
front quater guard braces
front and rear cusco strut braces
whiteline adjustable panhards rod
adjustable caster rods
cusco tension rod brace
caster rod bracket brace
6 point cage
harness bar
ultra racing chassis bracing
ultra racing front quarter guard bracing
Brakes:
Front and Rear disc brakes
Front and Rear Slotted Rotors
Project mu pads allround
Braided brake lines front and rear
Lights:
car is a original trueno so its got pop up headlights.
PRICE : $13000cash $15000swaps
contact : Mike (0405394871) if i dont pick up leave a message)
Attached thumbnail(s)
https://www.sau.com.au/forums/topic/312765-ae86-trueno/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
