Hey guys, got a few spare R33 GTS-T S1 parts left over.
- R33 Bonnet in Black. It was originally Burgundy but was sanded down and sprayed in matt black (for rwc). Overall in excellent condition apart from a slight line/ding thing at the top left (see photo). Not easily visible. Great as spare/track use or to clear defect. No water jets or heat shield.
Price: $130
post-59581-1269171537_thumb.jpg post-59581-1269171544_thumb.jpg post-59581-1269171551_thumb.jpg post-59581-1269171558_thumb.jpg
- R33 Front bumper. Recently re-sprayed in black. also have ordered indicators. Great condition.
Price: $130
- R33 Rear Bumper. Factory black. Few scratches. Nothing Major. Great condition.
Price: $110
Pick-Up from Berwick - 3806, South East Melbourne or you can arrange freight (I've used these guys before [Trans Direct], for bonnet you can use these dimensions [150cm x 150cm x 10cm] and 20kg for weight, should be around $30 in Melbourne)
I can be contacted via PM or on 0423 893 095
https://www.sau.com.au/forums/topic/312804-r33-s1-body-parts-black-in-colour/
  • 3 weeks later...
do you know if the front bumper would fit a s1 r33 non turbo mate?
Very sure its fits as all r33's have the same front except the GTR, unless someone else here doesn't think so????
We can try it on if you like!
Very interested in the front bar, when you say your ordered the indicator do you mean you will be supplying them with the bumper for that price?
Although initially I didn't plan to give it away with the front bar for that price but I can do both for $130 if your keen!!!
Indicators alone cost $80 :P
sorry mate wouldnt let me send a PM lol... but i will let u kno ASAP.. just gotta work out spraying costs cuz my 33 is silver so i will let u kno in the next couple of days pending its not sold by then cheers mate
dude i wanna come look at the bar, what condition is it honestly? any big marks or scuffs cuz im gonna have to get it resprayed to match my car
PM your contact details and we can orgainse something cuz im from S.E suburbs as well
cheers
yes it will
will only fit any series one car.
R33 GTS-T Bonnet still available.
Willing to swap for stock R33 gts-t wheels with good tyre (can work on cash adjustments), OR
LINK ECU Management HAND CONTROLLER.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
