R33 S1 Body Parts - Black In Colour
Hey guys, got a few spare R33 GTS-T S1 parts left over.
- R33 Bonnet in Black. It was originally Burgundy but was sanded down and sprayed in matt black (for rwc). Overall in excellent condition apart from a slight line/ding thing at the top left (see photo). Not easily visible. Great as spare/track use or to clear defect. No water jets or heat shield.
Price: $130
post-59581-1269171537_thumb.jpg post-59581-1269171544_thumb.jpg post-59581-1269171551_thumb.jpg post-59581-1269171558_thumb.jpg
- R33 Front bumper. Recently re-sprayed in black. also have ordered indicators. Great condition.
Price: $130
- R33 Rear Bumper. Factory black. Few scratches. Nothing Major. Great condition.
Price: $110
Pick-Up from Berwick - 3806, South East Melbourne or you can arrange freight (I've used these guys before [Trans Direct], for bonnet you can use these dimensions [150cm x 150cm x 10cm] and 20kg for weight, should be around $30 in Melbourne)
I can be contacted via PM or on 0423 893 095
  • 3 weeks later...
Very interested in the front bar, when you say your ordered the indicator do you mean you will be supplying them with the bumper for that price?
Although initially I didn't plan to give it away with the front bar for that price but I can do both for $130 if your keen!!!
Indicators alone cost $80 :P
sorry mate wouldnt let me send a PM lol... but i will let u kno ASAP.. just gotta work out spraying costs cuz my 33 is silver so i will let u kno in the next couple of days pending its not sold by then cheers mate
 Share
    • Another complicated thing is to run Z32 alloy hubs which have wheel speed sensors for ABS. You need different tie rod end, and you need new bearings on the upright etc. I did that as part of a major refresh when my front kingpin bearing flogged out., Alloy was a little lighter, runs a bigger bearing , gives a few extra mm in wheelbase as it moves the wheel forward in the arch (cant run crazy but can still get 8ish comfortably).   All in all glad I did it but was a head fark as tried it once and abandoned it the first time. sav man swung his spanners at it and got it working so using his guidance on GTR/Z32 tie rod ends etc and the required mismatch of parts was able to make it work.  Probably a 2k upgrade all said and done :(   I think the best bet is just look around your front wheel and see what you can pick up rotationally. You see old Escorts, E30s etc all get very creative with front uprights and the humble old angled alloy bracket.
    • Big claims here.  Any links up on the website ?
    • If your HP goal is reasonable and you are not drifting. Buy a new R34 box.  If the above is not true, buy a wrecked R33 box and put a gearset in it.  CD09 are not as strong as you think and the cost of / mess around of the conversion puts you in gearset territory.    Also the deal above is awesome,, get that
    • Just got back from a little hands-on with a G58 Baron....I was thinking about this... ..best I can figure it, that pinny was tail-ended ...I didn't really think about the wiring, because all that mattered was the tank and pump cradle (I think I mentioned the pump itself I couldn't vouch for)...which didn't matter, as you said you'd be replacing the pump anyway.... ...'for some reason'....and I imagine this is the panel shop's doing... they've replaced the cradle wiring with a metre of 7-core trailer loom, and attached the loom plug (from a different car) to that. The actual cable run from the top of the pump cradle, to fuel pump harness end in boot, is maybe 60cm in length...so I've no idea why they did this... ....the connector in the boot of the pinny, is not going to help you here...because in theory, it should still be present on your car. On top of that, because they've done what they did, we have no idea which colours of the trailer cabling, have been connected to what on the fuel pump cradle (pump +/- , shield, fuel guage/low-level senders)... ...this means, best approach is to remove the pump cradle, and re-work it now ...not later. That is, if you were going to replace the pump, do it, replace the soft lines at the same time...and sort the wiring out (replace that trailer cable with the wiring loom off your old cradle)...
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
