Gtr/gtst Parts, High Flowed Turbos And Other Parts
Hey all,
Have a few turbos and other bits and pieces to get rid of :
Two hiflowed gtr turbos, steel wheel Ball bearing standard housing sizes. Turbo's have only seen about 15 thousand k's as my motor threw a bearing.
Excellent condition and you can hear them spinning for ages after the car is off... really going to miss these.
want $1000 for them.
I have two GTST turbo's one with the actuator on it the other without it. 300 for the one with the actuator on it and 250 for the other one.
ZERO shft play in both, excellent condidtion.!
Have a mines ECU for an R32GTR : $300
2 R33 RB25det ECU's, : 100 each
Carpet from R32GTR : Make on offer
G-Sensor from GTR : make me an offer
R33 GTST/GTR Radiator : $100
GReddy boost guage with all the bits and peices, Black face : $150
Center guages from R32 GTR : $50
R32GTR glovebox : offer
More to come, will update when I check what else I have.
Send me a message I will be checking this regularly :(
Cheers all!
 Share
    • Big claims here.  Any links up on the website ?
    • If your HP goal is reasonable and you are not drifting. Buy a new R34 box.  If the above is not true, buy a wrecked R33 box and put a gearset in it.  CD09 are not as strong as you think and the cost of / mess around of the conversion puts you in gearset territory.    Also the deal above is awesome,, get that
    • Just got back from a little hands-on with a G58 Baron....I was thinking about this... ..best I can figure it, that pinny was tail-ended ...I didn't really think about the wiring, because all that mattered was the tank and pump cradle (I think I mentioned the pump itself I couldn't vouch for)...which didn't matter, as you said you'd be replacing the pump anyway.... ...'for some reason'....and I imagine this is the panel shop's doing... they've replaced the cradle wiring with a metre of 7-core trailer loom, and attached the loom plug (from a different car) to that. The actual cable run from the top of the pump cradle, to fuel pump harness end in boot, is maybe 60cm in length...so I've no idea why they did this... ....the connector in the boot of the pinny, is not going to help you here...because in theory, it should still be present on your car. On top of that, because they've done what they did, we have no idea which colours of the trailer cabling, have been connected to what on the fuel pump cradle (pump +/- , shield, fuel guage/low-level senders)... ...this means, best approach is to remove the pump cradle, and re-work it now ...not later. That is, if you were going to replace the pump, do it, replace the soft lines at the same time...and sort the wiring out (replace that trailer cable with the wiring loom off your old cradle)...
    • Well, maybe not. The main feature of Chinese manufacture seems to be incredibly variable quality, coupled with an apparent willingness to find a way to see even the stuff that fails QC. So the military could still take the cream of the production run and somehow sell the "sellable but not really useable" stuff to the stupid round eyes on the other side of the world.
    • Have you adjusted the clutch pedal rod? You can wind it in to shorten it. Just can be a cnut to get to.
