Your luck as one of the better painters is in your area
(On Day road)Not sure of the name of the shop but i will ask Bruce tomorrow but theirs no one better with trim than Peter at Trimcare, see Wheelspin for lots of pretty stuff and the ugly bald guys at SST can make the power to match the looks.
Join the New club and display your car as part of the team.Good luck with your project.
OK From what I have seen at the auto salons they are not really concerned about performance unless you have a 800 KW monster! Pauls pulled 400 and got a small trophy just like what i got at motorvation, kinda means not that much.. anyways unfortunately i spent most of my $$$ on power 4 shows later a small trophy and couple of photo shoots and that really all i have had for $50 K now if i wanted a show car like what you are tlkaing about spend a few grand on the generals as listed but spend $$ polishing engine bay, paint and interior as you have alreay said. most of all... BE CREATIVE! THAT IS HOW YOU WILL WIN! so if your after performance don't expect much if you want looks then you will win in shows but not much street cred!... anyways all the bost, my interior was done by classic auto trimmers i think in morley. mechanics by PSI performance, SST and turbo help from Grant at Performaz next to SST. I use Alpha 1 panel and paint in Osborne Park.
Hope this helps
just my 2.2 cents
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
