Hey people
I have got the rb25Det I put into my 31 running with everything connected including vct, afm, cooler... And it won't rev above 2400.....
I read it's most likely afm or tps... How can I check these?
It sounds like it's hitting a rev limiter.... Just before boost....
Any ideas?
Thanks
https://www.sau.com.au/forums/topic/312971-rb25-not-revving/
Ok, well its in failsafe which is why it has a 2500ish rpm rev-limit...
Perform self diagnostic (will be a thread in DIY section if you don't know how) & check for codes.
If you have none try wiggling AFM plug & revving car to see if it suddenly revs higher.
If not try same with TPS. Did you do your own wiring conversion?
With no ECU LEDs & no dash light not really... Maybe a light can be hooked up directly?
Like use a pin-out to find which wire is check engine light & maybe it can be wired to a light/LED.
No idea if it would work but only thing I can think of...
hey people,
i have changed the AFM it fixed the limp mode problem straight away....
i have another problem though....
the engine is missing.
i though bad fuel at the start, cos its been sitting in the garage for about 2 months, on very low fuel, so i drove to the petrol station, added octane booster as well as premium, and let it run for a while. still missing on the way home, as soon as i pulled into the garage, it stopped missing, and was running sweet. so jumped back in to take it for a proper test drive, and it started missing straight away.
i have a 044 fuel pump and surge tank, and the pump makes some funny noises like its sucking in air, but surge tank is full... i have never run an 044 before so i am unsure whether noises are standard or pump is fu#ked.
i have changed plugs to NGK BKR5EIX-11
if i fiddle with the CAS and turn it completely anticlockwise, it sounds a tiny bit better....
also, when i back off throttle, the car almost stalls, sometimes does stall.
revs around 900 at idle
just trying to give as much detail as possible....
cheers people
Did you change plugs before or after replacing AFM?
If you done plugs, were in failsafe, then replaced AFM & now have a miss maybe you have just fouled plugs...
Car runs very rich in failsafe & for free worth cleaning & refitting plugs
it misses at idle and under load.....
plugs were changed before AFM was changed....
ill try narrow it down to a certain cylinder tomorrow, and take plugs out to see if fouled.....
car is running very rich at the moment, but probably cos one cylinder not firing?
it really cant be anything else besides coil pack or plugs can it?
cheers
hey again
ok, its cylinder 3 from the front of the block thats not firing.
when i unplug the coil pack, engine keeps missing just the same, if i unplug any of the others, it runs worse....
i swapped the coil pack with number 1, and still number three not working.
spark plug not firing.... so i swapped the plug with a new one, and still no go.....
oh, also, running pfr5g-11 plugs.
any ideas?
Thoroughly check your coilpack loom. If possible remove that section of loom (connects just behind head, maybe half a foot after cylinder 6 coilpack.
Then test the resistance/continuity of all wires from loom connector to coil plug. If 3 is dramatically different from the others I would hazard a guess you have a broken or damaged wire, etc Someone else may know of a more common problem but first thing I would check...
i checked resistance in coil pack wiring, and coild pack wiring is ok. so my problem is between the coil pack plug on engine loom, and the ECU.
as a easier fix, can i piggy back the earth wire from the other coil pack that fires at the same time as cylinder 3? or will this present problems at high revs?
cheers
please guys, i am desperate for help!
i dont know what is going on with my car.....
cylinder 3 is not firing at all. there is continuity in all wires to the coil pack loom from all plugs.
after testing wires, i determined that coil packs turn on via the earth connection in the plug....
the only way i can get cylinder 3 to spark is if i piggy back the earth wire from another coilpack onto the earth wire to cylinder 3 coil pack, but i am thinking none of the cylinders fire together cos it still misses.....
its not a faulty coil pack or spark plug.
it cant be injector related cos spark plug is wet when i pull it out
does any other cylinder fire at the same time as cylinder 3 from the front of the engine?
does anyone know the pin out on the ECU for cylinder 3 coil pack so i can trace continuity to ECU???
i HAVE SEARCHED AND SEARCHED, BUT NO ONE I CAN FIND HAS THIS PROBLEM....
what is going on?
just wanted to finish up this tread for anyone else who has teh same problem in the future....
problem was injector not firing, and as a fail safe, the ECU will not give signal to coil pack to spark if injector is not firing to prevent leaning out...
cheers
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
