hey hey
i got a hdi electronic boost controller with a boost guage n had it installed, after that was having issues with misfire and other things.
i then wired it up so i bypassed the boost controllers solenoid i thought this would run stock boost but now its running 12.5 which is way too high considering its on lowest setting.
any idea as to why its running so high?
https://www.sau.com.au/forums/topic/312992-boost-issues/
In the thread below SKYPER says that he has tested a few R32 wastegate actuators and they were higher then 10psi, they varied around 12psi.
http://www.skylinesaustralia.com/forums/Rb...-U-t312106.html
Plus a full exhaust so 12.5psi sounds ok. As Hypergear said remove the boost controller from the system and see what just the wastgate actuator runs at.
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5145471
thanks mate that gives me a bit of relief haha, thought i bought i dodgy boost controller, wasted 350 bucks.
ill run it the actuautor and see what happens, thanks guys
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5145482
well i got my spark plugs changed and the car is running well when im not using the boost controllers solenoid, still around 12 but i can deal with that for now. as soon as i put the vacuum hoses to go through the ebc's solenoid and take it for a drive the boost shot up to like 16 psi and was going to keep going untill i took my foot off the accelerator.
im 99% sure its wired up correctly, the ebc is a hdi sbc d or something, the one that comes with the really bright boost gauge, also if the key is turned on the acc should the boost guage be reading a number? if so what number, thanks
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149166
Good work. So as you have probably worked out the wastegate actuator on your car operates at 12psi. This is a minimum boost pressure so you cant go below it.
When you introduce the boost solenoid it spikes to 16psi and above, so your boost controller is not setup correctly.
Sorry I cant help with that specific boost controller.
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149181
haha thanks, i was told it was 10 by a few people so i was a bit confused :P
ive tried everyway the boost controller can be set up, looks like ill have to spend some more time trying to figure it out, serves me right for not going for the profec
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149190
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
