hey hey
i got a hdi electronic boost controller with a boost guage n had it installed, after that was having issues with misfire and other things.
i then wired it up so i bypassed the boost controllers solenoid i thought this would run stock boost but now its running 12.5 which is way too high considering its on lowest setting.
any idea as to why its running so high?
https://www.sau.com.au/forums/topic/312992-boost-issues/
In the thread below SKYPER says that he has tested a few R32 wastegate actuators and they were higher then 10psi, they varied around 12psi.
http://www.skylinesaustralia.com/forums/Rb...-U-t312106.html
Plus a full exhaust so 12.5psi sounds ok. As Hypergear said remove the boost controller from the system and see what just the wastgate actuator runs at.
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5145471
thanks mate that gives me a bit of relief haha, thought i bought i dodgy boost controller, wasted 350 bucks.
ill run it the actuautor and see what happens, thanks guys
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5145482
well i got my spark plugs changed and the car is running well when im not using the boost controllers solenoid, still around 12 but i can deal with that for now. as soon as i put the vacuum hoses to go through the ebc's solenoid and take it for a drive the boost shot up to like 16 psi and was going to keep going untill i took my foot off the accelerator.
im 99% sure its wired up correctly, the ebc is a hdi sbc d or something, the one that comes with the really bright boost gauge, also if the key is turned on the acc should the boost guage be reading a number? if so what number, thanks
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149166
Good work. So as you have probably worked out the wastegate actuator on your car operates at 12psi. This is a minimum boost pressure so you cant go below it.
When you introduce the boost solenoid it spikes to 16psi and above, so your boost controller is not setup correctly.
Sorry I cant help with that specific boost controller.
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149181
haha thanks, i was told it was 10 by a few people so i was a bit confused :P
ive tried everyway the boost controller can be set up, looks like ill have to spend some more time trying to figure it out, serves me right for not going for the profec
https://www.sau.com.au/forums/topic/312992-boost-issues/#findComment-5149190
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
    • Each to their own I guess  Me, I put just as much time into cleaning inside of the cars as I do on the outside As for getting wet, it is really no different than steam cleaning the carpets at home, apart from the cars carpet dries alot faster than the house, again, I only do it in the hotter months and leave the car opened up for a few hours As I only do it yearly, it is just before I do the diff and gearbox service, so I clean the carpets, then it's up on stands, wheels off, service, clean the undercarriage,  grease the bushings and do a nut and bolt check on everything  Disclaimer: I typically had all the time in the world to kill when I was working 馃ぃ, so spending a full day or 2 cleaning, serving and "looking at stuff" was,  easily achievable, and a fun mental therapy day As for time to kill, I retired last Wednesday, so apart from my physical training, my days are filled with lots of random jobs around the house and garden...."Idle hands are the Devils something something" I am also buying a new house sooner rather than later, I'm actually looking at a potential property tomorrow, I'm looking forward to getting a car hoist as I'm starting to get to old to crawl around under a car, I can only imagine all the undercarriage cleaning and looking at stuff when that gets set up
    • Yeah, I'm not interested in wetting the carpets, and I don't care about brown dirt/dust that lives deep in the pile or underneath. It's not like I crawl around on them in my birthday suit or eat dropped food off them (because there is never any open food in my car). The seats are alcantara (cheap Chinese imitation alcantara, to be sure!) with barely 1" of foam pad behind the surface. That's not getting wet either. Any car that I would be happy to get the interior wet, I would not care to put the effort into.
    • We have one that holds 2.8L of water. On floor carpet that hasn't been touched in 2 or 3 years, will take a minimum of 2 fills of the tank to do a bedroom, and that's going AROUND the bed.   In the cruiser, I used an ENTIRE 2.8L tank, just on the front passenger footwell. But it had some fungus growing, and had been full of mud from being used as a 4WD for many years. I can do that floor again, and it will still pull mud out. However, the water now only looks dirty, not pitch black and leaving full sludge in the bottom of the tank it sucks back into. Oh, and, this is about a $1500 unit.
    • This is mine, works a treat for the cars, suction is good, I use the Bissell clean and protect stuff I have found giving it a good spray and light scrub with the soft brush on the head of the nossle for carpet, and a rub with a microfibre for cloth seats and cloth door trims, prior to another quick spray before vacuuming it up works the best @GTSBoy You would surprised on what it gets out of carpet and seats that actually "look" clean, I recommend that you test drive yours when you have a little time to kill, then post pics of the muddy looking water that I believe you will find
