Okay so car is no longer for sale. Being stripped after mates scab all the parts they want from it.
So atm the 2 main items that need to go are engine and box.
Both items come from relatively stock r33 GTST 1.5, never over boosted etc etc.
RB25det
-just under 140,000
-all standard
-slight waterpump leak (can be fixed on removal of car if price is right)
only things not included is ecu, turbo or therafter, cooler and cooler kit.
Basically anything under the hood other than above items can be arranged in sale.
Price-$1900
R33 GTST manual gearbox
-just under 140,000
-drives, shifts lovely
-heavy duty organic extreme clutch inc
-comes with tailshaft if necessary
Price-$1800
Both these Items still in running in car and can be tested and inspected. Will get compression test later
this week, but dont see any problems.
Item location: Dandenong north VIC
Items will be removed in dandenong south VIC (mates workshop) upon sale.
Delivery can be arranged in sale for local suburbs. (s.e suburbs)
Also willing to ship if necessary
Contact Details: PM or 0423292542
Cheers, Brad
https://www.sau.com.au/forums/topic/313009-rb25det-gearbox-package-for-sale/
both these items come with all necessary brackets and bolts to bolt staight up.
Gearbox comes with clutch pedal, and gearstick with stndard gearknob.
Engine comes with loom.
Edited by d_33vl_1
price revised to make a quicker sale.
RB25det-
comes with
-loom and ecu
-manifold
-oil lines and water lines
-all associated wiring
-afm
-rad and hoses
Slap on a turbo and start the thing
(only not coming with- turbo, cooler and piping, exhaust)
PRICE- $1700
Gearbox-
comes with
-crossmember
-tailshaft
-clutch (extreme heavy duty organic)
-selector, shifter
-slave cylinder
PRICE- $1600
Both these items can be delivered locally (sth E vic), or couriered.
If you come to pick it up, first dibs on anything else needed.
GEARBOX IS SOLD. WOOHOO
(pending payment next w/e)
Engine comes with heavy duty clutch as g'box buyer does not want it.
RB25det-
comes with
-loom and ecu
-manifold
-afm
-rad and hoses
-HEAVY DUTY CLUTCH
PRICE- $1700
price drop again
$1300.00
engine will be out of car hopefully tomorrow.
ne contact numbe asi'm now without a job (was business phone)
0422056446
inspection can be made tomorrow in dandenong south before removal
    • Also, a tip for young players  Check the dates on new tyres before they fit them, I always ask this question at the tyre shop, as they have tried to put "new" tyres on one of my cars a few years ago, but the build date was about 3 years old
    • Yeah - 4 or 5 years is the limit for decent tyres. Pedestrian grade tyres with 400 TW ratings start out hard and don't start to suffer until they are somewhat older again. But the stickier decent stuff? Nup. My current ADO9s are < 2 yrs old, 17000km in, only have about the minimum 2mm of tread depth left, and they are.....not what they used to be. They are clearly much harder now than when new. Whether that is heat cycles (unlikely, for a road tyre), different compound between top and bottom of tread, or actually aging out (in less than 2 years!!!) is not really able to be discerned. But I'd credit actual aging as being at least part of the cause. I've got an old pair of ~50% worn AD08Rs in the shed that I really need to get rid of. They started feeling waaaay too hard to put back on the car after a couple of years sitting there.
    • Personally I wouldn't put tyres over 4 or 5 years old on any of my own cars. Once they go hard the grip characteristics completely change. As per most things it only matters in an accident and that's when you most want them to do their job!
    • I'm replacing the front tyres on the E39 tomorrow because one of them has a few gouges out of it. There is so much tread still on them but they're also 9 years old and the rubber is super hard.  This falls within the guidelines of 10 years old that I've read which surprises me given their condition.  I'm curious about whether you guys care about tyre age or just judge the tyre based on condition? How old would you consider too old?
    • What starts as a scratch, becomes a flesh wound, then quadruple amputation. Jus' sayin'. Crush resistant gloves (The ones with the rubber strips down the back of the hand and fingers) might not be a bad idea after all!
