Hey all, just wanting to know weather i can get away with out relocating it providing i can get a belt the right size
so heres a few questions for those of you who do alot of these
Is it really nessicary to relocated the tensioner if so what are your reason?
has anyone got an idea on the length/size/number of teeth required for the belt to be used with standard location of idler and tensioner
I have always re-located it above the water pump as per the DET guide. I don't think there is a right/wrong way of doing it, as long as you can still get the correct tension on the belt, all is good.
Re-locating does make releasing/tensioning the belt a lot easier but. Saves having to remove the lower cover each time.
I have a mate who located his differently to me, and had to cut part of his lower cover away. Just don't go getting all creative like he did, serves no purpose.
Just read the rb30det guide it's all in there. Belt part number for tensioner above the water pump is Dayco 94407. 152 teeth.
Here is a link to a rb30det belt which I assume requires no re-location, I have nfi if you need to use 2x lower tensioners or not but;
http://justjap.com/store/product.php?produ...at=0&page=1
It's all too easy now for the new rb30 twin cam kids on the block lol, you even get your belt off the shelf.
Edited by James_03
fair enough, didnt think of that haha, i guess i'll have to drill it now.
It's either drill, or cut. And it looks much neater to drill.
I will soon be looking for new covers for my motor when I change to the new block.
yeah, i'll be drilling and relocating it now didnt want to as this is an ultimate budget slap together but.. i guess i gotta do it :)
just weld some extensions onto the top cover (this is what was done with mine) and you barely notice it once it is all painted up.
I'm getting ready to drill/tap mine right away here. Should a guy use the exact dimensions in the guide ie. 17.7 mm from the deck and 33 mm to the right of that small hole looking at the front of the block?
  • 4 months later...
Sorry to bring this back up guys, but I will be doing this soon and was just wondering does anyone have any tips of drilling perfectly straight (90*) to the block as I don't like the idea of the tensioner being on an angle even if very slight. Don't want the belt jumping off or anything like that, so how have you guys done it?
doesnt have to be perfect if you have the machined surface there, when you tighten up it'll pull itself square.
i used one of the gates belts off just jap and drilled exactly where the guide says to but couldnt even get the belt on, was too far out. ended up using 2 tensioners down the bottom and the belt went straight on, wtf?
thanks, I don't think I will be getting it machined as I'm on a budget and the engine shop in my town is a mega rip off, but I'd assume it's already pretty flat.
HI there
If you are getting the gates belt that is specifically designed for the rb30 conversion, then you don't need to relocate the tensioner (in fact I don't think it's long enough). In terms of the belt rubbing on the covers, I'm not sure what the issue is - I used an rb30e bottom timing belt cover and the normal rb26 top one, and it seemed fine - the belt was close but it won't rub. I also extended the bottom cover by welding on a bit of carefully folded sheet metal (this is the bit that creates a risk of rubbing IMO so as long as you do that bit carefully should be fine).
most 30 blocks are machined there from the factory
just finished bolting my covers on, used the standard 30 bottom cover and 25 top cover and it clears the belt fine
  • 1 month later...
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
