has anyone else welded a bit around the base just on the one side so the tensioner won't hit? because my thread isn't so great, the tensioner stud is tight in there and doesn't move around, but i dunno if thats enough for me
from personal experience, the just jap rb30de belts are 150 teeth, which if going high compression n/a the teeth meet in the middle before getting the right tention (i ground 0.030" off the block and 0.080" off the head to get 10.5:1)
i know of someone making a carbon fibre rb30de lower cover mould, (who is also making the top and coil pack cover mould for the rb26)
in that case you'd probably have to relocate the tensioner, but it wouldnt be the same spot as the guide, you'd have to figure out exactly where it needs to go.
but for a standard 30det the gates belt and stock locationed tensioners works well, just make the bottom cover on the left side clears the belt by atleast ~10mm. myne cleared on the engine stand but now rubs ever so slightly at a certain rpm and load
I dummy assembled the head block crank cams etc at work, i put a bit of bearing blue on the end of the stud (10mm by 1.5 thread pitch if anyone is looking for the tap / heli-coil set) and yeah it matched what the rb30de guide says. so I heli-coiled it
the gates t306 is the 150 teeth is what i got from just jap
but then i got the gates t291 152 teeth from repco for like $30 (Audi A4 1997-2000 1.8lt 4 cylinder turbo)
also came across this last weekend during my search
SUCCESS
Belt Guide:
Upper Tensioner Relocation Method.
Required Belt Length: 1216 mm
Required Belt Width: 25 mm
Required Tooth Pitch: 8mm
Required Tooth Profile: Trapezoidal (prefered) or Modified Curvilinear
Required Number of Teeth: 152
Compatible Belts:
Gates T291
Goodyear Gatorback 40291
Bosch BT866
Dayco 94680
Dayco 94407
Continental Contitech CT919 (OEM volkswagen belt supplier)
Factory Position - Dual Lower Tensioner Method.
Required Belt Length: 1200 mm
Required Belt Width: 23 to 25 mm
Required Number of Teeth: 150
Compatible Belts:
Gates T306
Goodyear Gatorback 40306
Bosch BT306
Dayco 94777
Continental Contitech CT909 (OEM volkswagen belt supplier)
Gates PowerGrip GT2 1200-8MGT-30, cut down to 25mm from 30mm at factory (still pending)
This is a list of belts that i've compiled through comparing my new T291 belt to the stock SOHC dayco replacement belt for the RB30E. It fit exactly the same around the crank sprocket, so I did some sleuthing and cross referencing, and this is a list of belts that SHOULD be compatible.
When I say SHOULD, I mean that someone mentioned the GT2 to be compatible, and it was not. These belts are in comparison to the level of compatibility shown by the GT2. Even if you've got a GT2 on your DE conversion, it most likely does not fit as well as these ones listed above do.
mmm, I never thought of using a heli-coil I might try that, only reason I'm not using the original location is im doing this build for a friend and he wants it cheap and i got the 152 belt for $19
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
