Hey everyone I was on the way to work
and a truck pulled in front of me so I put the foot down to overtake it and I noticed
boost spike kicked in :s I was only half foot nd boost hit around 11-13 psi (as soon as I saw it
I backed off)
no bang no knocks nothing I didn't rev the car for a while for it to bulid boost but later I took of from the lights and around 3000 rpm I can at least hear a little bov but there was nothing ...
Look at the guage and it's not building and pressure :blink:
is the turbo goneskies ??
Cheers everyone
you wont get any bangs or knocks even at that amount of boost mate as i have been running 14.4psi on my stock rb20det hoping it would kill the turbo but 8 monthes later its still going so dont freak out over a couple of boost spikes.check all lines associated with the turbo i.e turbo charge in/out lines or if u have a boost controller also check all lines to this for splits and melting if thats all good maybe a faulty boost controller as my old bleed tap type did this.my ruff rule of thumb - lots of smoke mass loss in power =blown turbo. - not making boost properly or spiking = dodgy boost controller or installed wrong ect ect. -wacko idle and wont rev properly = mass air leak ie cooler piping ect.just my rule of thumb maybe not what others would do but thats just my opinion.hope it helps a little mate and good luck.
-J.R
Can you hear any unusual noises when under load (ie when the turbo would normally be creating boost)? If you have any hissing/screeching noises you may have a boost leak.
Check all your intercooler pipes for loose clamps/ splits or blown hoses.
If you are getting 'bov' noise it is unlikely your turbine wheel has fallen off, so I would be looking at a boost leak first, then checking to see if your internal wastegate flap is stuck open.
If all that fails, unbolt the cat and look for ceramic!
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
