Sony Xplod - 2 X 15" Subs & 1 X 1400 Watt D Class Amp
Item Summary: Sony Xplod - 2 x 15" Subs & 1 x 1400 Watt D Class Amp As Brand New in Boxes, Only fitted for 3 weeks
Condition: Used
Reason for Selling: No longer have a car that they fit in!
Asking Price: 120
Delivery Methods: Pick Up or Freight
Contact Info: PM Us here.
Extra Information:
2 x Sony Xplod 15 inch Subs, 1500 Watt Model XS-L152P5 - $120 each or $200 for both.
1 x Sony Xplod Specialty Series 1400 Watt D Class Amp, Model XM-SD61X - $350.
OR $500 for the lot.
All in original Boxes with Original Packaging, User Manuals, Wiring & Templates.
These were only fitted in our Supra for 3 weeks, we now have a baby boy and a newer model car with a stock stereo so have no need for these anymore. Selling cheaply now as we are moving to a smaller home in a couple of weeks and as we no longer need this equipment, there's no sense packing it up and taking it with us. Would prefer collection by this weekend but absolutely no later than Friday the 2nd of April 2010.
We are willing to freight at Buyers Cost & Organisation. This means you liase with you courier, get your own quotes and pay them direct. I will package your item and have it ready for collection by your courier company at your preferred time.
Located in Redland Bay, QLD 4165 - Brisbane/Gold Coast.
NO SWAPS!!!
Any questions, just ask :)
 Share
    • With same diff ratio, tyre diameter and road speed, the tailshaft rpm is the same regardless of the gearbag's ratio. Given that very quick drag cars are probably doing similar road speeds to the fastest circuit cars (circa 300 km/h), and there will be many of either category that can't go that fast and so you'd have inummerable matchups between drag and circuit car speeds at smaller numbers, and given that they are probably using rather similar tyre diameters and probably using similar diff ratios, and...where any of those numbers were different they could quite easily be in opposite directions thus cancelling out.... I think you'd find that there'd be more similarity than difference in tailshaft speed between these two use cases, no?
    • they might see those prop shaft speeds for 1 to 2 secs only
    • A year of slogging through this bearing issue and finally fixed. What a nightmare. The oil pressure increase did not fix the problem. If you would like to read all the details in case you ever run into a similar issue visit my thread on Yellow Bullet. https://www.yellowbullet.com/threads/continuous-rod-bearing-issues.2689569/?post_id=74193031&nested_view=1&sortby=oldest#post-74193031 In the end the rod bearings themselves were the issue. I had switched from ACL (first engine) to King because that was all we could get at the time and I thought nothing of it. Put the ACL's back in after a year of taking the pan off multiple times to change many things. Issue resolved. Can't believe it was just the bearings themselves all along. It has now been about two years since I drove the car on the street or had it at the track. At some point I had installed all solid and spherical bushings in the rear but had never aligned it since it just went on and off the dyno. Alignment was the first thing to do. (Old photo but same concept) Then I took the transmission out and went through it. This was my first gearset install and I've done about 15 since this one and learned a lot and wanted to apply some of these tweaks to mine. The aftermarket shift forks take very well to some modification and I wanted to make that change. Shifts are now super smooth and no having to find the gear. I also recut the 5th and reverse shift sleeves - always wanted to try this and see how well it works. It works very well! No grinds or having to do a second attempt going into reverse and 5th is perfect. Before During After Going back in In rummaging through my spare trans parts box I found the only parts I've ever broke on a stock trans; the 3-4 shift fork - twice!
    • It also depends on gearbox ratio. Those drag cars running 7s passes aren't doing it on an overdrive gear ratio (probably). 1:1 is "fine", the critical RPM for a 50' single driveshaft in chromemoly is 6900rpm.... ....but when you shift into 5th and use 0:73 or 0:8 it all changes. Do you know their rear diff ratio? etc. That's the stuff that matters with regards to it. Whether it actually matters given your use application is also relevent. You may never get into those scenarios, like most ruined GTR's from Western Sydney don't :p
    • but for how long? would it handle a few laps around SMSP in anger?
