gday all! got a whole heap of stuff that i need to get rid of as listed.prices as listed or make an offer im easy going.
all items located s.e suburbs vic melb or i dont mind sending if needed.thanks
- rb20det redtop - no loom,ecu,clutch,flywheel.everything else is there and complete ie injectors,plenum,exhaust manifold ect ect
has done 102,000kms from memory.out of an r31 half cut.engine is strapped to a pallet for easy moving.looking for $450ono
- r31 silhouette - rolling shell,has most of interiour but i think was changed with a r31 executive.all dash components are there body is pretty good
just a bit of a deep scratch on front passenger quater.series 2 pretty sure.also pretty sure this has an r32/r33 cross member in it as it had an rb25det in the bay when i bought it.will part out or take the whole thing - $offers$
- rb25 gear - as follows:
-stock sump -offers
- stock crank - offers
- head s2 - need repairs to exhaust manifold bolt holes - $150
- stock exhaust manifold - offers
- stock dump pipe - offers
- turbo elbow - offers
- altinator - offers
- stock plenum with throttle body - offers
- full loom - has a changed AFM plug to either z32 or rb30 afm's otherwise uncut - offers
- injectors - side feed purple's with fuel rail.have been told these are an upgrade but honestly not sure - offers
- rb20det gear as follows:
-AFM - good working order,all mesh fine no dents - $50
- clutch - 30% more clamp than stock used for about 7000kms.will get you out of the sh*t. -offers
- flywheel - may need a machine but looks fine - offers
- cam timing covers - i have a few of these one is painted metallic blue with the lines under "rb20" on the cover have been smoothed over and looks great -offers
r32 gtst gear:
- GAB strut brace - bit scratched otherwise good - $40
- BN sports (i think) rear bar - its big......real big!! in primer has been fitted but not really used no cracks ect - $160ono
Random gear as follows:
- rb30 afm - offers
- 4 bolt wastegate - hks copy - offers
- magnaflow dual tip exhaust - 3" dual tips out of muffler - offers
- blast pipes - 2 1/2 in,2 3/4 or 3" dual blast pipes in stainless steel polished. -$110ono
will be posting more as i find/locate more parts in my seemingly endless shed.will part out if people want the bits.
can post or email any pics needed or wanted upon request not an issue.
PM.email ([email protected]) or sms 0402605401 for faster response
https://www.sau.com.au/forums/topic/313114-for-salerb2025det-skyline-stuff-lk/
yeh r31 shell is rolling gimme $100 and take it mate.
wastegate is a 38mm =D
rb25 head is complete minus cam covers.can come with some rb20det cover if wanted.can take exhaust manifold and plenum if wanted also.
cheers =D
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
