Anyone know how well the vacume ones work on turbo cars where the power delivery isn't liner ??
My last car had cruise, and it killed me going to a car without it :)
Stimps - does the one you've got work on the tacho signal as well ?? I've never installed one that runs on the magnets etc....
The one i have works off the magnets on the tailshaft system, which is if anything, more accurate.
Being a turbo car or not makes no difference.
If you have a turbo auto, its even better, as when you come to a steep hill, it will simply apply more throttle, turbo spools up, auto kicks down a gear....etc..
I havent played with any of them that work off a tacho signal, but I would think that any that does, would be pretty dodgy, as the behaviour of it would change depending on which gear your in.
Cool,
Yeah, the one I had in my last car was done via the tacho and used to get confused on steep hills etc. But it was pretty old (bought it about 12 years ago).
Might put one on my wish list.
BTW: I like what you did with the uhf transmitter. Good idea to keep the dash nice and neat.
J
mine was $750 fitted - so if you did it yourself it should be cheaper, I just needed it very quickly and didn?t have the time.
On the vacuum ones, I'd been warned off them for the turbo skyline, but I don?t know if it is a correct warning or not?
And most of the decent cruise controls should just work of the SPEED wire, not the tacho one, so it is irrelevant which gear you are in..
there is nothing wrong with the vacumn ones on a turbo car.
All turbo cars should have a hose taking vacumn off the manifold, thru a one way valve, to a vacumn resivior somewhere on the car (in the VL's its on the right hand side hidden behind the bumper.)
Even when your on boost, there is plenty of vacumn on hand to deliver power to the actuator to pull the throttle cable.
If it doesnt work, something is wrong, ive seen people have problems and blame the cruise control when I've had a look and found that the one way valve is missing or installed the wrong way around.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
